StarTech.com USB 3.1 / eSATA 1-bay Dock
£61.39
Delivery:
Standard: 1-3 working days
Key features
  • Connect and access a 2.5" or 3.5" SATA SSD/HDD over USB 3.1 Gen 2 or eSATA
  • Access drives at full speed with support for SATA I, II and III (up to 6Gbps)
  • Top-loading design with built-in ejection button for easy drive access
  • Type: HDD docking station
  • HD Size: 2.5", 3.5"
  • Stock Status: In Stock
Product codes
Dock and access your SATA SSD/HDD through high-performance USB 3.1 (10Gbps) or eSATA. Connect and access any 2.5" or 3.5" SATA hard drive or SSD using this single-drive docking station, over a USB 3.1 Gen 2 (up to 10Gbps) or eSATA connection.
Ideal for IT professionals, the docking station lets you access a SATA solid-state drive or hard drive quickly, for drive imaging, data recovery, and backups.
You can connect through either USB 3.1 Gen 2 or eSATA, and take advantage of the high performance of the latest SSDs and HDDs.
The dock's vertical drive insertion makes it easy to dock and swap drives from your desktop computer or laptop. You simply insert your SSD or HDD into the drive slot at the top of the docking station, with no tools or trays required. The HDD ejection button allows fast and simple drive removal.
The single-bay docking station comes with a USB Type-A to Type-C cable, for connecting to newer USB-C enabled devices. It also comes with a USB Type-A to Type-B cable, providing backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. An eSATA cable is also included with the dock.
The docking station is also UASP compatible, for enhanced performance.
Product Description StarTech.com Drive Docking Station for 2.5 / 3.5" SATA - USB 3.1 or eSATA - HDD docking station - SATA 6Gb/s - eSATA, USB 3.1 (Gen 2)
Device Type HDD docking station - external
Bays 1
Bus Type eSATA, USB 3.1 (Gen 2)
Colour Black
Expansion Bays 1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility 2.5", 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive, solid state drive
Max Storage Devices Qty 1
Product Material Plastic
Power AC 120/230 V
Dimensions (WxDxH) 9.3 cm x 14.5 cm x 6.52 cm
Weight 500 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.1 /...
£61.39
