StarTech.com USB 3.1 2.5/3.5" SATA Adapter
£34.74
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Access a SATA SSD or HDD from your desktop or laptop with this SATA to USB cable
  • Transfer data faster at up to 10Gbps with this USB 3.1 cable
  • Experience 70% faster read speeds and 40% fast write speeds with UASP support
  • Stock Status: In Stock
Product codes
Easily access, transfer and backup data from a SATA drive to your PC or laptop, through USB 3.1. This USB 3.1 to SATA adapter gives you fast and easy access to the data on your 2.5 in./3.5 in. solid-state drives and hard drives. The adapter cable lets you connect your laptop or desktop computer directly to a SATA drive and access it through ultra-fast USB 3.1 Gen. 2 (up to 10Gbps).
This adapter cable lets you quickly swap your drives. You can copy or retrieve data from your 2.5 in. or 3.5 in. SATA drive, with no additional accessories required.
The tool-free adapter cable is ideal for IT technicians who need fast access to SATA drives. It's the perfect solution for data migration, drive cloning, and data backup or recovery applications, providing the fast performance of USB 3.1 Gen 2. You can also operate multiple adapters at the same time, when you require simultaneous access to many drives.
USB 3.1 Gen 2 gives you greater bandwidth and speed with rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
The compact, lightweight design of the USB 3.1 to SATA adapter provides easy portability. The adapter features an integrated 1 m cable, so you never to worry about forgetting to bring your connector cable with you.
You can connect easily to a 2.5 in. solid-state drive or hard drive, using USB power, with no external power required. A universal power adapter is included for use when connecting to your 3.5 in. drives or for any 2.5 in. drives that may require additional power.
Product Description StarTech.com SATA to USB Cable - USB 3.1 10Gbps - SATA 2.5 / 3.5" SSD HDD - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
Device Type Storage controller - external
Bus Type USB 3.1 (Gen 2)
Colour Black
Hard Drive Form Factor Compatibility 2.5", 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive, solid state drive
Power AC 120/230 V
Dimensions (WxDxH) 2.45 cm x 8.5 cm x 2.1 cm
Weight 80 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.1 2...
£34.74
