StarTech.com USB 3.1 Gen 2 Enclosure
£43.60
Delivery:
Standard: 1-3 working days
Key features
  • Create high capacity external storage for a 3.5” SATA HDD with USB 3.1 Gen 2 high-speed performance
  • Supports SATA I, II and III (tested up to 6 Gbps)
  • UASP support for enhanced performance
  • Type: Storage enclosure
  • HD Size: 3.5"
  • Stock Status: In Stock
Product codes
The high-speed, high-capacity data storage solution you've been waiting for - with USB 3.1 Gen 2. Now, get the speed and capacity you want in external data storage. This single-drive enclosure for 3.5" SATA hard drives gives you high-speed USB 3.1 Gen 2 (10 Gbps) performance with a large drive capacity of up to 6TB.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSHDs and hard drives, while alleviating bottlenecks in your data transfers.
The clean and simple design makes this enclosure the perfect desktop companion for your Mac or PC. It's made of durable aluminum with a fan-less design that ensures quiet operation. It also comes with a vertical stand so it occupies minimal space in your work area.
This versatile enclosure comes with a USB Type A-to-B cable, providing backward compatibility with existing USB ports or hardware. It also provides UASP support for enhanced performance.
Product Description StarTech.com USB 3.1 Gen 2 External Hard Drive Enclosure for 3.5" SATA Drives - Fan-less UASP Enhanced Single Drive Enclosure (S351BU313) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Device Type Storage enclosure - external
Bus Type USB 3.1 (Gen 2)
Colour Black
Expansion Bays 1 x internal - 3.5"
Hard Drive Form Factor Compatibility 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 10 GBps
Supported Devices Hard drive
Product Material Aluminium
Power Source USB bus
Dimensions (WxDxH) 7.7 cm x 12 cm x 1.55 cm
Weight 130 g
Designed For P/N: BNDTBUSB3142, HB30C3A1CFB, HB30C3A1CFS, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.1 G...
£43.60
