This USB 3.1 external hard drive enclosure offers a rugged, high-performance solution for accessing and backing up your important files, while protecting your drive in harsh environments. It comes with two cables, to support both USB-C and USB-A enabled laptops and tablets.
Product Description | StarTech.com 2.5" SATA SSD/HDD Hard Drive Enclosure - USB 3.1 (10Gbps) External Hard Drive Case - IP65-Rated Enclosure (S251BRU31C3) - storage enclosure - SATA 6Gb/s - SATA 6Gb/s, USB 3.1 (Gen 2) | Device Type | Storage enclosure - external | Bus Type | SATA 6Gb/s, USB 3.1 (Gen 2) | Colour | Black | Expansion Bays | 1 x internal - 2.5" | Hard Drive Form Factor Compatibility | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Hard drive, solid state drive | Max Storage Devices Qty | 1 | Power Source | USB bus | Dimensions (WxDxH) | 11.2 cm x 14.6 cm x 3 cm | Weight | 200 g | Manufacturer Warranty | 2-year warranty |
General | |
Hard Drive Maximum Height | 9.5 mm |
Host Bus | SATA 6Gb/s, USB 3.1 (Gen 2) |
Colour | Black |
Storage Controller | |
Processor | ASMedia ASM235CM |
Expansion / Connectivity | |
Interfaces | 1 x SATA 6Gb/s - SATA combo |
Connections | 1 x USB 3.1 (Gen 2) - 24 pin USB-C |
Miscellaneous | |
Cables Included | 1 x USB-C to USB-A cable - external , 1 x USB-C cable - external |
Features | USB powered, rugged, tested with up to 2TB 7200 RPM 2.5" hard drives, S.M.A.R.T. support, TRIM support |
MTBF | 48000 hours |
Compliant Standards | FCC, RoHS, MIL-STD 810G, WEEE, UASP (USB Attached SCSI Protocol) |
Power | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 11.2 cm |
Depth | 14.6 cm |
Height | 3 cm |
Weight | 200 g |
Environmental Parameters | |
Min Operating Temperature | -40 °C |
Max Operating Temperature | 85 °C |
Humidity Range Operating | 20 - 95% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
