StarTech.com USB 3.1 Tool-free Enclosure
£24.55
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Create portable external storage for a 2.5” SSD/HDD with USB 3.1 Gen 2 high speed performance
  • Tool-free design and lightweight enclosure for easy portability
  • USB A to Micro B cable for easy compatibility
  • Type: Storage enclosure
  • HD Size: 2.5"
  • Stock Status: In Stock
Product codes
Get the faster speed of USB 3.1 Gen 2 in a lightweight and portable storage solution. Now it's easier than ever to access your data wherever you go. This USB 3.1 Gen 2 (10 Gbps) single-drive enclosure for 2.5" solid-state or hard drives gives you an ultra-fast, portable external storage solution.
Engineered with a durable and lightweight housing, the enclosure tucks easily into a laptop bag or carrying case for portable storage. It's completely tool-free so you can install your drives quickly on the fly.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfer.
The enclosure connects easily to a host computer, with no external power required. It comes with a USB A to Micro B cable, providing backward compatibility with existing USB ports or hardware. It also provides UASP support for enhanced performance.
Product Description StarTech.com USB 3.1 (10Gbps) Tool-free Enclosure for 2.5" SATA Drive - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Device Type Storage enclosure - external
Bus Type USB 3.1 (Gen 2)
Colour Black
Expansion Bays 1 x internal - 2.5"
Hard Drive Form Factor Compatibility 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 10 GBps
Supported Devices Hard drive, solid state drive
Product Material Plastic
Power Source USB bus
Dimensions (WxDxH) 8.8 cm x 13.2 cm x 1.5 cm
Weight 70 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.1 T...
£24.55
