StarTech.com USB 3.1 USB-C to USB-A Adapter
£13.42
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Connect your USB Type-C device to a USB Type-A device, with this durable adapter. Have you purchased a new device that only came equipped with a USB Type-C or Thunderbolt 3 port, such as a laptop or tablet? Do you need to connect to older USB 3.0 or 2.0 devices?
This USB-C to USB-A adapter makes it easy to connect USB 3.0 and 2.0 devices to new USB-C devices. Simply plug the adapter into the USB Type-C port to turn it into a USB Type-A port, and you're ready to connect your older devices. The adapter is compatible with USB 3.0 enabled computers, such as the Dell Latitude 11 5000 2-in-1, and more.
USB 3.0 is also known as USB 3.1 Gen 1 (5Gbps).
StarTech.com 6in USB C to A Adapter Cable M/F - USB 3.0 - USB-IF Certified - USB-C adapter - 15.2 cm
USB-C adapter
Double shielded
Length
15.2 cm
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type A - female
USB 3.0
2 years warranty
Apple MacBook
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.1 U...
£13.42
