StarTech.com USB 3 Encrypted HDD Enclosure
£86.61
33 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ensure your external drive data is secure and locked with real-time encryption
  • Hassle-free operation, with a built-in touchpad
  • Fits SATA drives
  • Plug-and-play installation
  • Compatible with USB 3.0
Product codes
Turn a 6 Gbps HDD or SSD into secure external storage with touchpad password entry. The S2510BU33PW USB 3.0 encrypted hard drive enclosure lets you to turn your 2.5-inch SATA hard drive (HDD) or solid state drive (SSD) into an AES-encrypted external drive.
To ensure all of the data on your drive is protected from unauthorized access, the secure enclosure uses an Advanced Encryption Standard Algorithm (256-bit AES). Once your encryption is set, access to the content is only authorized through a customized PIN that you set and enter using the sleek built-in touchpad. The encryption is hardware based, eliminating the hassle of complicated software installation and configuration.
The hard drive enclosure ensures maximum performance, with support for USB 3.0 transfer speeds up to 5 Gbps. The enclosure also supports SATA III drives, ensuring you can still achieve high performance while accessing your SATA 6 Gbps SSD externally.
Product Description StarTech.com Encrypted - storage enclosure - SATA 6Gb/s - USB 3.0
Device Type Storage enclosure - external
Bus Type USB 3.0
Colour Black
Expansion Bays 1 x internal - 2.5"
Hard Drive Form Factor Compatibility 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive, solid state drive
Max Storage Devices Qty 1
Product Material Plastic, steel
Dimensions (WxDxH) 7.7 cm x 12.3 cm x 1.4 cm
Weight 94 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3 Enc...
£86.61
