StarTech.com USB-C Adapter - HDMI and VGA
£91.38
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Expand the connectivity of your MacBook Pro or Windows USB-C laptop, by connecting to a 4K HDMI or VGA display
  • Power the adapter and your laptop at the same time, using your laptop’s USB-C based power adapter (supports USB Power Delivery 3.0)
  • Utilize both the SD and microSD card readers at the same time
Product codes
Add video output, three USB 3.0 ports, SD/micro SD card readers, and GbE port to your laptop through a single USB-C port. Turn your USB-C equipped laptop into a mobile workstation. This sleek, compact USB-C multiport adapter makes it easy to connect your MacBook Pro or Windows laptop to an HDMI or VGA monitor. Power through your workday, with three USB 3.0 (Type-A) ports with Fast-Charge support, SD and microSD card slots, and a Gigabit Ethernet port.
The universal USB Type-C multiport adapter (Thunderbolt 3 port compatible) offers enhanced productivity in the boardroom or classroom. Connect your laptop to one external monitor: 4K HDMI (3840 x 2160p @ 30Hz) or VGA (1920 x 1200 @ 60Hz).
With support for USB Power Delivery 3.0 (up to 85W), the USB-C multiport adapter lets you power and charge your laptop, and power your peripherals at the same time. PD 3.0 features Fast Role Swap to prevent USB data disruption when switching power sources (bus power and USB-C power adapter).
Connect your USB devices using the three USB 3.0 (Type-A) ports. Each USB port is a fast-charge and sync port, to ensure your tablet and smartphone are charged and ready. Each port offers 7.5W of charging power, with a combined total of 10W with all three ports in use.
Access the SD and microSD slots at the same time, and easily move data from one card to the other.
For mobile use, the USB-C adapter is bus-powered and lightweight, with a wraparound USB-C cable.
StarTech.com USB-C Multiport Adapter w/ HDMI and VGA - 3x USB 3.0 - SD - PD - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
Max Resolution Details
HDMI: 3840 x 2160 at 30 Hz / VGA: 1920 x 1200 at 60 Hz
Network (RJ-45) , VGA (female connector) , HDMI (female connector) , 3 x USB 3.0 (female connector) , USB-C (female connector)
7 cm x 12.2 cm x 1.4 cm
Enclosure Colour
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C Ada...
£91.38
