Ideal for mobile workers, this USB-C multiport adapter with HDMI and VGA gives you flexible video output. It's like four adapters in one, with HDMI or VGA connections, a Gigabit Ethernet port and a USB 3.0 port, all through one connection to your laptop's USB-C port. Plus, it features a hideaway cable for better cable management and easier travel.
With easy plug-and-play installation on most operating systems, the USB-C adapter doesn't require additional drivers or software. It's the perfect accessory for MacBook Pro, Dell XPS, Chromebook or other USB-C laptops.
The USB Type-C multiport adapter keeps you prepared for business travel. You can extend your laptop's display by connecting to a 4K HDMI (4096x2160 or 3840 x 2160p) or VGA (1920 x 1200p) monitor or projector, to make presentations or set up a workstation.
With multiple ports and an easily accessible hideaway cable, the USB-C all-in-one adapter makes an ideal travel dock, for easy connections on the go. Plus, the USB Type-C adapter is bus powered, so there's no need to carry around a separate power adapter.
Connect a flash drive, mouse or other peripheral to your USB-C or Thunderbolt 3 laptop using the USB 3.0? Type-A port. The USB-C adapter adds wired network connectivity with the GbE port, making it ideal in areas without Wi-Fi.
Product Description | StarTech.com USB C Multiport Adapter with HDMI, VGA, Gigabit Ethernet & USB 3.0, USB C to 4K HDMI or 1080p VGA Display Mini Dock Hub, USB Type-C Travel Docking Station for USB-C Laptops - Portable USB-C Dock (DKT30CHVCM) - docking station - USB-C - VGA, HDMI - GigE | Product Type | Docking station | Docking Interface | USB-C | Video Interfaces | VGA, HDMI | Dimensions (WxDxH) | 6.5 cm x 10.5 cm x 1.6 cm | Weight | 82 g | Colour | Black | Networking | Gigabit Ethernet | Manufacturer Warranty | 3-year warranty |
General | |
Width | 6.5 cm |
Depth | 10.5 cm |
Height | 1.6 cm |
Weight | 82 g |
Enclosure Colour | Black |
Video | |
Max Resolution Details | 4096 x 2160 - 24 Hz (HDMI only) , 3840 x 2160 - 30 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only) |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab |
Expansion / Connectivity | |
Interfaces | 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x USB-C cable - integrated - 8.5 cm |
Features | USB powered |
Compliant Standards | FCC, RoHS, UASP (USB Attached SCSI Protocol) |
System Requirements | |
OS Required | Google Chrome OS, Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.11 - 10.14 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Weight | 200 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
