USB Type-C Headphone and Charger Adapter Audio & Charge 60W PD. This USB C audio adapter with 60W power delivery features a USB Type-C audio port for your headset, audio out or data transfer, while allowing you to charge your laptop, tablet, or smartphone at the same time.
Listen & Charge Simultaneously
Make calls or listen to music with this USB C audio and charging adapter. The 2 in 1 headphone adapter with charge port allows you to use your USB-C headsets, speakers, or transfer data (USB 2.0 speeds) while simultaneously charging your device through Power Delivery pass through with Type C power adapter connected.
Sleek and Portable Design
The USB C audio adapter features a cable-less, dongle design with a convenient side-port layout to reduce cable clutter, making it perfect for professionals at their workstation or on-the-go. Constructed of high-quality materials, the portable adapter provides a reliable and affordable audio and charge solution for your USB Type-C devices.
Wide Compatibility
This USB C headset adapter is universally compatible enabling you to use your wired headphones with your USB Type-C or Thunderbolt 3 device, including the MacBook Pro, iPad Pro, Samsung Galaxy and Note.
CDP2CAPDM is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
Product Description | StarTech.com USB C Audio & Charge Adapter, USB-C Audio Adapter with USB-C Audio Headphone/Headset Port and 60W USB Type-C Power Delivery Pass-through Charger, For USB-C Phone/Tablet/Laptop - USB-C Audio/Charging (CDP2CAPDM) - docking station - USB-C | Product Type | Docking station | Docking Interface | USB-C | Dimensions (WxDxH) | 2.25 cm x 4.99 cm x 0.9 cm | Weight | 8 g | Colour | Silver | Manufacturer Warranty | 3-year warranty |
General | |
Width | 2.25 cm |
Depth | 4.99 cm |
Height | 0.9 cm |
Weight | 8 g |
Enclosure Colour | Silver |
Expansion / Connectivity | |
Interfaces | USB-C with Power Delivery (60 W) - 24 pin USB-C , Audio - USB 2.0 - 24 pin USB-C |
Miscellaneous | |
Features | 60W power delivery |
Compliant Standards | FCC, RoHS, WEEE |
System Requirements | |
OS Required | Android, Windows 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 9 cm |
Shipping Depth | 12.5 cm |
Shipping Weight | 9 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
