StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0
£11.44
15 In Stock
Delivery:
Standard: 1-3 working days
  • Length: 1m
Product codes
Charge your USB 2.0 USB-C devices, such as your MacBook or Chromebook, from a USB-C AC wall charger. This USB-C to USB-C cable lets you charge and sync your USB Type-C devices. It's also compatible with Thunderbolt 3 ports.
Connect your newer USB-C mobile devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, to your computer. The cable delivers up to a 3 amp charge, and supports data transfer speeds of up to 480Mbps.
With up to 3A of power output, this USB Type-C cable can also be used to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect your laptop to your USB-C wall charger.
Replace the cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
The USB Type-C connector is smaller and easier to use than previous USB connectors. With a reversible design, you can plug it into your devices with either side facing up. Insert the cable the right way every time - no more frustration or port damage.
This USB-C cable has been certified with USB-IF (USB Implementers Forum) in order to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards set by USB compliance. This ensures a high-quality, reliable cable for all your USB-C devices.
Product Description StarTech.com 1m / 3.3ft USB C to USB C Cable - USB 2.0 Type C Cable - M/M - USB-IF Certified - USB C Charging Cable - USB 2.0 (USB2CC1M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
Type USB-C cable
Technology Double shielded
Features 480 Mbps data rate
Length 1 m
Connector 24 pin USB-C - male
Connector (Second End) 24 pin USB-C - male
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: DKT30CHD, HB30C1A1CPD, HB30C3A1CFBW, PEXUS313AC2V
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£11.44
