USB Type-C Multiport Adapter - Triple 4K with DP 1.4 & HDMI 2.0 - 100W PD - 6x Downstream USB Ports
This USB-C Gen 2 10Gbps docking station turns your USB-C or Thunderbolt 3 Windows laptop or Chromebook into a powerful workstation. A USB 3.2 Gen 2 Type-C dock features everything you need, from triple video outputs up to 4K 60Hz to 10Gbps USB-C & USB-A downstream peripheral ports to 100W Power Delivery.
HDMI & DisplayPort for Multiple Monitor Outputs
This USB-C Gen 2 docking station with DP 1.4 and HDMI 2.0 HBR3 support, is a perfect choice for dual or triple monitor setup, supporting up to triple 4K 30Hz nearly uncompressed video resolution output , with two DisplayPort and one HDMI outputs. Maximum dual and triple 4K display performance is supported on USB-C 11th Gen Intel-based (DP 1.4 HBR3 with DSC support) Windows Thunderbolt 3 or USB-C laptops, but backwards compatibility to older laptop generations and lower resolution monitor requirements.
DP 1.4 HBR3 with DSC Enabled
DP 1.4 HBR3 (without DSC)
DP 1.2 HBR2
Triple Display
Up to 4096 x 2160 @ 30Hz
Up to 1920 x 1080 @ 60Hz
Up to 1600 x 900 @ 60Hz
Dual Display
Up to 4096 x 2160 @ 60Hz*
*HDMI port + DP port or 2 DP ports
Up to 2560 x 1440 @ 60Hz
Single Display
Up to 3840 x 2160 @ 60Hz
Up to 3840 x 2160 @ 30Hz
Power & Charge with 100W Power Delivery
Power and charge USB-C/Thunderbolt 3 workstation laptops & ultrabooks with 100 watt power delivery, to keep high performance laptops sufficiently charged during heavy productivity usage.
Charge smartphones and other devices with USB-C downstream charging ports featuring BC 1.2 charging specification. Fast-charge ports support always-on charging so devices will charge whether or not a host laptop is connected.
Integrated 6-Port USB Hub & SD Card Reader
This USB-C Gen 2 docking station features 6 downstream USB ports in total to connect USB peripherals and an SD (4.0) card reader for media storage.
2x USB-C 3.2 Gen 2 - 10 Gbps (BC 1.2 Fast-Charge + Aways-On)
2x USB-A 3.2 Gen 1 - 5 Gbps
2x USB-A 2.0 - 480 Mbps
SD 4.0 Card Reader
Also included, is a gigabit Ethernet port with PXE Boot, as well as 4-position TRRS stereo audio for a headset and mic.
Additional Security Features
This USB-C docking station comes with plenty of security features two K-slots for a Kensington style laptop lock.
Connected Device Transparency with the StarTech.com MAC Address Changer Utility
The DK31C2DHSPDUE includes a free Windows application that enables you to better manage your enterprise network security. When you connect to your network through the ethernet port of the dock, the computer's MAC address is typically not broadcast to the network, as your network only sees the MAC address of the docking station. However, the StarTech.com MAC Address Changer or Cloning software enables the USB-C dock to use MAC address spoofing of the connected Windows laptop rather than the MAC address of the dock itself. This ensures your network administrators have full visibility of each device on the network and can monitor and limit activity accordingly. To request access to our MAC Address Changer utility, please contact our Technical Support Department by phone, live chat, or e-mail.
Product Description | StarTech.com USB C Dock - Triple 4K Monitor USB Type-C Docking Station - 100W Power Delivery - DP 1.4 Alt Mode & DSC, 2x DisplayPort 1.4/HDMI 2.0 - 6xUSB (2x 10Gbps) - Windows/Chrome - docking station - USB-C - HDMI, 2 x DP - GigE | Product Type | Docking station | Docking Interface | USB-C | Video Interfaces | HDMI, 2 x DP | Dimensions (WxDxH) | 21 cm x 9 cm x 3 cm | Weight | 300 g | Colour | Grey | Localisation | United Kingdom, Europe | Networking | Gigabit Ethernet | Power | Power adapter 100 Watt AC 120/230 V | Manufacturer Warranty | 3-year warranty |
General | |
Width | 21 cm |
Depth | 9 cm |
Height | 3 cm |
Weight | 300 g |
Enclosure Colour | Grey |
Video | |
Max Resolution Details | 4096 x 2160 - 60 Hz (DisplayPort 1.4 only) |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab |
Expansion / Connectivity | |
Expansion Slots | 1 (total) / 1 (free) x SD / MMC Memory Card |
Interfaces | 1 x display / video - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x display / video - 20 pin DisplayPort , 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 2 x USB-C 3.1 Gen 2 with Battery Charging 1.2 , 2 x SuperSpeed USB 3.0 , 2 x USB 2.0 |
Miscellaneous | |
Cables Included | 1 x USB-C cable - detachable - 1 m , 2 x power cable |
Features | 2 security lock slots (cable lock sold separately), Preboot Execution Environment (PXE) support, up to 3 monitors support, DisplayPort Alt Mode, 100W power delivery, HDR support |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC, RoHS, WEEE, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.4, DSC |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V |
Power Provided | 100 Watt |
System Requirements | |
OS Required | Apple iOS, Windows 8.1 / 10, Google Chrome OS 69.x, Apple macOS 10.12 - 11, Android 9.x |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 27 cm |
Shipping Depth | 15 cm |
Shipping Height | 9.4 cm |
Shipping Weight | 1.4 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
