StarTech.com USB-C Dual-4K Monitor Docking Station for Laptops
£198.81
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Turn your USB-C equipped laptop into a dual Ultra HD 4K workstation by connecting two external 4K monitors: 1x DisplayPort (DisplayLink) 4K @ 30Hz and 1x HDMI (DP Alt Mode) 4K @ 30Hz
  • Universal USB-C dock supports macOS and Windows
  • Powers and charges your laptop, with 60W USB Power Delivery 2.0
  • Device Type: Laptop
  • Type: Docking Stations
  • Stock Status: In Stock
Product codes
Add dual monitors (4K HDMI & 4K DP), an SD card reader, multiple USB ports, GbE, and audio to your laptop, plus power and charge your laptop. This dual-monitor USB-C dock transforms your MacBook or Windows laptop into a dual Ultra HD 4K workstation, with support for 4K DisplayPort and HDMI monitors. It gives you all the connections to create a fully capable workstation, including an SD card reader slot.
The USB-C docking station features USB Power Delivery 2.0 (60W), to power and charge your laptop as you work. It's the perfect companion for your MacBook Pro or other Thunderbolt 3 equipped laptop.
The USB-C dock expands the display capabilities of your laptop across two Ultra HD 4K monitors. It enables DisplayLink and USB-C DP Alt Mode to allow dual 4K video output to HDMI and DisplayPort 4K monitors. With the dual-4K dock, you can connect: 1x 4K DisplayPort display at 3840 x 2160 resolution @ 30Hz; 1x 4K HDMI display at 3840 x 2160 resolution @ 30Hz.
The dock provides direct access to your SD memory cards or microSD cards (with adapter). The SD card slot can also be used for additional storage and backup through macOS X Time Machine or Windows 10 File History.
The dock provides four USB 3.0 (Type-A) ports to connect your peripherals, including a USB 3.0 fast-charge and sync port, a Gigabit Ethernet port, and combined 3.5 mm audio and microphone port.
Compatible with Mac and Windows, this universal dock works with USB-C and Thunderbolt 3 enabled laptops.
Product Description StarTech.com USB C Dock - 60W PD - 4K Dual-Monitor Laptop Docking Station - DP & HDMI - SD Card Reader - Mac & Windows (DK30CHDDPPD) - docking station - HDMI, DP
Product Type Docking station
Docking Interface USB-C
Video Interfaces HDMI, DP
Dimensions (WxDxH) 8 cm x 22 cm x 2.5 cm
Weight 385 g
Colour Black, silver
Localisation United Kingdom, Europe
Networking Gigabit Ethernet
Power Power adapter 60 Watt AC 120/230 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C Dua...
£198.81
