This USB-C to HDMI MST Hub allows you to connect two HDMI monitors, using a USB-C enabled host device.
Product Description | StarTech.com USB-C to Dual HDMI MST HUB, Dual HDMI 4K 60Hz, USB Type C Multi Monitor Adapter for Laptop w/ 1ft (30cm) cable, DP 1.4 Multi-Stream Transport Hub, USB Type C to 2x HDMI Ports - USB-C to HDMI Splitter (MST14CD122HD) - adapter - DisplayPort / HDMI | Cable | Adapter - DisplayPort / HDMI | Max Output Resolution | 3840 x 2160 - 60 Hz | Colour | Grey | Connector | 24 pin USB-C - male | Connector (Second End) | 2 x HDMI - female | Compliant Standards | DisplayPort 1.4 | Features | Display Stream Compression (DSC), HBR3 audio support, DisplayPort Alternate Mode support, Multi Stream Transport (MST), 7.1 channel Surround Sound | Manufacturer Warranty | 3-year warranty |
General | |
Cable Type | Adapter |
Interface Supported | DisplayPort / HDMI |
Colour | Grey |
Adapters & Converters | |
Max Output Resolution | 3840 x 2160 |
Refresh Rate | 60 Hz |
OS Required | Microsoft Windows 10 / 11 |
Connectivity | |
Connector (Second End) | 2 x 19 pin HDMI Type A - female |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight | |
Width | 10.5 cm |
Depth | 4.3 cm |
Height | 1.4 cm |
Weight | 55 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.2 cm |
Shipping Depth | 17 cm |
Shipping Height | 3 cm |
Shipping Weight | 110 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
