StarTech.com USB-C Ethernet Adapter with Extra USB Port - USB...
StarTech.com USB-C Ethernet Adapter with Extra USB Port - USB 3.1 Type-C
£41.37
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Add a Gigabit Ethernet network connection to your computer through a USB Type-C port
  • Works with the newest MacBook, Chromebook Pixel and other laptop and desktop computers with a USB-C port
  • Thunderbolt 3 port compatible
  • Add a USB Type-A port to your computer for connecting an additional peripheral device
  • Native driver support in Chrome OS and Windows , and macOS
  • Powered directly from the USB port
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Type: Network adapter
Product codes
USB-C to Network Adapter 10/100/1000Mbps Thunderbolt 3 Compatible RJ45. This USB-C Ethernet adapter connects you to a Gigabit network through the USB-C or Thunderbolt 3 port on your laptop or desktop computer and adds connectivity for an additional USB (Type-A) peripheral device.  It's a great companion for your MacBook, Chromebook or Windows  laptop with an available USB-C port.
Powerful Gigabit Network Connections
The USB-C network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.1 Gen 1. You can quickly access very large files over the network at Gigabit speed.
Native Driver Support Makes Installation Easy
Get up and running quickly. Simply plug the adapter into the USB Type-C port on your laptop and connect to your network. The network adapter chipset provides native driver support in Chrome OS , Windows , and macOS.
Trouble-Free Connections Through USB-Type-C
The USB-C connector is smaller and easier to use than previous USB connectors. It's a reversible plug so you can connect to your devices with either side facing up, without frustration or the risk of port damage.
With a compact design, this USB-C network adapter is as portable as your laptop, perfect for ultra-portable devices that have a USB-C port, such as the MacBook and Chromebook Pixel . The network adapter is bus-powered which makes it easy to connect when you're on the go.
Additional Connectivity With an Extra USB 3.1 port
Some computers with USB Type-C only offer one port for external connectivity. This Ethernet adapter features a built-in USB Type-A port, giving you the freedom to attach an additional peripheral device, such as a USB mouse.
The US1GC301AUW is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Product Description StarTech.com USB C to Gigabit Ethernet Adapter with USB A Port, White 1Gbps NIC USB 3.0/USB 3.1 Type C Network Adapter, 1GbE USB-C RJ45/LAN TB3 Compatible Windows MacBook Pro Chromebook - USB C to Ethernet (US1GC301AUW) - network adapter - USB-C - Gigabit Ethernet + USB 3.1 Gen 2
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB-C
Ports Gigabit Ethernet + USB 3.1 Gen 2
Dimensions (WxDxH) 3.5 cm 1.7 cm
Length 27.5 cm
Weight 38 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3az, USB 3.1
Colour White
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows 2003, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Linux Kernel 2.6.25 - 4.11.x LTS versions, Apple MacOS X 10.11 - 10.14
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£41.37
