StarTech.com USB-C Laptop Dock - MST and PD
£123.10
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easily connect dual monitors (DisplayPort and HDMI) right out of the box, with no display driver setup
  • Connect your USB devices with 4 x USB 3.0 ports - 1x USB-C and 3x USB-A (including 1x Fast-Charge)
  • Power and charge your laptop with Power Delivery 2.0 (up to 60W)
  • Stock Status: In Stock
Product codes
Power and charge your laptop through USB Type-C (5Gbps), and create an MST based, dual-monitor workstation. Here's a must-have accessory for your USB-C equipped laptop. This dual-monitor docking station is one of the first to integrate the next-generation USB-C host connector, so you can easily power and charge your laptop through its USB Type-C port. And, because it supports MST, you can connect multiple monitors through just one DisplayPort connection.
With power delivery, MST, dual video (DV), or 4K Ultra HD support, this innovative docking station caters to a range of users, such as IT administrators, designers and animators.
USB-C is here. It's the future of universal connectivity, and many new laptops and tablets already feature USB Type-C ports. This versatile laptop dock capitalizes on the full potential of USB Type-C, which simultaneously transfers power, video, and data.
This docking station supports USB Power Delivery (up to a maximum of 60 watts), so you can power and charge your laptop directly through its USB-C port. Because a single power adapter can be used for your dock and laptop, you can reduce clutter at your workstation. Plus, you don't need to carry or remember an extra power adapter when you're traveling to or from the office.
Typical USB Type-A docks restrict video and data to 5Gbps shared bandwidth. This USB Type-C dock allocates data and video traffic separately, so extra bandwidth can be diverted to a particular video or data function, as needed. The USB-C laptop dock offers optimal performance when using multiple monitors and peripherals, so you can get more work done in less time.
This versatile dock gives you two options for connecting dual monitors. With more monitors, you can multitask and increase productivity, by eliminating the hassle of flipping between several open windows.
For dual video, you can easily connect your DisplayPort and HDMI monitors. Alternatively, you can connect multiple monitors to the dock's DisplayPort connection using MST, making it easy to connect multiple DP 1.2 monitors in a daisy chain.
This dual-monitor docking station with MST makes it easier to deploy multiple displays of the same type across organizations, businesses, or hot desks. It can help you save money on volume monitor purchases, and it makes it easier to manage and troubleshoot problems.
The USB-C laptop dock features a DisplayPort and an HDMI port, giving you the flexibility to connect your displays as needed. It supports dual monitors or a single high-resolution 4K monitor.
For extra screen space, this dock offers support for the higher 4096 x 2160p resolution, unlike traditional 4K docking stations that only support 3840 x 2160p.
This full-featured universal docking station offers the ports you need to create a full-sized workstation, including four USB 3.0 ports (including a fast charge-and-sync port and a USB-C port), plus Gigabit Ethernet, audio, and microphone connections.
Product Description StarTech.com Dual Monitor USB-C Dock - Windows - HDMI/DP, 60W PD, 4xUSB 3.0 - docking station
Product Type Docking station
Docking Interface USB
Dimensions (WxDxH) 9.1 cm x 21 cm x 2.8 cm
Weight 133 g
Colour Black
Localisation Australia, North America, United Kingdom, Europe
Networking Gigabit Ethernet
Power Power adapter 90 Watt AC 120/230 V
Designed For P/N: ARMBARDUO, ARMDUAL, ARMDUAL30, ARMSLIMDUO
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C Lap...
£123.10
