StarTech.com USB C Multiport Adapter - 4K HDMI/PD/USB/GbE- Mi...
StarTech.com USB C Multiport Adapter - 4K HDMI/PD/USB/GbE- Mini Dock
£109.34
Delivery:
Standard: 1-3 working days
Key features
  • 5-IN-1 FUNCTIONALITY: USB-C multiport adapter (USB 3.1/3.2 Gen 2 10Gbps) supports 4K 30Hz HDMI video, with 2x USB-A (1x BC 1.2 fast charge), 1x USB-C (Data or 100W Power Delivery) & Gigabit Ethernet
  • EXTRA LONG CABLE: USB Type-C multiport adapter w/ 10" (25cm) attached cable for extended reach to reduce port/connector strain on 2-in-1 devices like Surface Pro 7, iPad Pro & laptops on riser stands
  • POWER FLEXIBILITY: USB-C mini dock is USB bus powered or use your external USB-C laptop power adapter supporting up to 100W Power Delivery (PD 3.0) passthrough (15W for dock & up to 85W for charging)
  • WIDE COMPATIBILITY: Adapter hub for USB-C Gen 1 & Gen 2 ultrabooks, Chromebooks, tablets & Thunderbolt 3 laptops like HP, Dell, Lenovo, MacBooks; works w/ Windows, macOS, iPadOS, Chrome OS, Android
  • PORTABLE & COMPACT: Portable all-in-one docking station design allows for easy transport in a laptop bag for convenient on-the-go use between office and home office, business travel
  • CONNECTIVITY TOOLS: Provided with this device, the application improves performance and security, featuring MAC Address Changer, USB Event Monitoring, Windows Layout & Wi-Fi Auto Switch utilities
Product codes
100W Power Delivery Pass Through 1X USB-C Port 2x USB-A Port 10" Attached Cable. This USB-C multiport adapter with HDMI turns your MacBook Pro, Dell XPS, or other USB-C laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, a USB Type-C port (data/power), two USB 3.2 Gen 2 Type-A (10Gbps) ports, and a Gigabit Ethernet port, all through one connection to your laptop's USB-C or Thunderbolt 3 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 10-inch (25 cm) host cable for an extended reach to offer more set up flexibility.
Enhance Productivity
The portable docking station connects your laptop to a 4K HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
Connect Your Devices
The USB-C to USB 3.2 Gen 2 hub gives you one USB-C port and two USB-A ports to connect your latest and legacy USB devices.
Charge Your Laptop and Peripherals
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
Reliable Network Connectivity
The Gigabit Ethernet port ensures reliable wired network access.
The DKT31CHPDL is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
Product Description StarTech.com USB C Multiport Adapter, 10Gbps USB Type-C Mini Dock with 4K 30Hz HDMI, 100W Power Delivery Passthrough, 3-Port USB Hub, GbE, Portable USB 3.1/3.2 Gen 2 Laptop Dock, 10" Cable - Portable Travel Dock - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 - HDMI - GigE
Product Type Docking station
Docking Interface USB-C 3.2 Gen 2 / Thunderbolt 3
Video Interfaces HDMI
Dimensions (WxDxH) 3.66 cm x 4.68 cm x 1.6 cm
Weight 94.5 g
Colour Grey
Networking Gigabit Ethernet
Power Power Provided
Designed For P/N: PEXUSB321C
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£109.34
