StarTech.com USB-C Multiport Adapter - DVI
£59.08
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Provides DVI video output, a USB 3.0 port, and a Gigabit Ethernet port to your USB-C Windows or MacBook Laptop
  • Power your laptop with 60W Power Delivery using this multiport adapter and a USB Type-C power adapter
  • Connect your existing USB devices using the USB Type-A port Gigabit Ethernet RJ45 port supports Wake-on-LAN (WOL), jumbo frames, VLAN tagging, and Energy-Efficient Ethernet
Product codes
Charge your laptop through USB-C and create a workstation wherever you go, with DVI video output, Gigabit Ethernet and a USB-A port. Expand the connectivity of your USB-C enabled laptop. This sleek USB-C multiport adapter lets you create a powerful workstation virtually anywhere, providing DVI video output, one USB 3.0 Type-A port, and a Gigabit Ethernet port.
You can also power both the multiport adapter and your laptop simultaneously, with support for USB Power Delivery 2.0. It's the ideal accessory for your Dell XPS, MacBook Pro or other USB Type-C equipped laptop, and it's also Thunderbolt 3 port compatible.
The multiport adapter expands the connectivity of your port-limited laptop, using the built-in USB-C cable to connect to multiple devices simultaneously. When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. Connect to a DVI display in an office workspace or your home office with ease.
The Gigabit Ethernet port ensures reliable wired network access, plus with an additional USB 3.0 Type-A port, you can connect an existing peripheral device, like your mouse or flash drive.
The Gigabit Ethernet port ensures reliable wired network access, ideal for areas with limited Wi-Fi availability.
This compact multiport adapter is USB-powered, so there's no need to carry a separate power adapter with you. Ideal for mobile use from office to home, or for travel, the multiport adapter features a USB-C port that supports USB Power Delivery 2.0 so you can power and charge your laptop as you work. The adapter features a built-in USB-C cable and gives you network connectivity plus a USB Type-A connection for optimum versatility as you travel.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
Product Description StarTech.com USB C Multiport Adapter, USB-C to DVI-D (Digital) Video Adapter with 60W Power Delivery Passthrough Charging, GbE, USB-A, Portable USB Type-C/Thunderbolt 3 Mini Laptop Dock - Dock with Ethernet (DKT30CDVPD) - external video adapter - white
Device Type External video adapter
Bus Type USB-C
Max Resolution 1920 x 1200
Interfaces Network (RJ-45) , DVI-I (female connector) , USB 3.0 (female connector) , USB-C (power only) (female connector) , USB-C (male connector)
Dimensions (WxDxH) 4.1 cm x 9.7 cm x 1.7 cm
Enclosure Colour White
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£59.08
