This USB-C Mini Dock / Multiport Adapter supports up to dual 4K 60Hz HDMI 2.0 converting your Dell XPS, MacBook or other USB-C laptop or tablet into a workstation, anywhere you go. The USB Type-C Multiport Adapter features 2x HDMI video outputs, a 2-Port USB 3.2 Gen 2 (10 Gbps) Hub (1x USB-A with B.C 1.2 charging, and 1x USB-C), an SD card reader, and Gigabit Ethernet. The adapter connects to your host computer's USB-C, USB4, or Thunderbolt 3/4 port. Charge your host laptop and any attached USB peripherals by connecting the host laptop's power supply to the dedicated USB Power Delivery (PD) 3.0 port. The Multiport Adapter features an extra-long attached 12-inch (30 cm) host cable - for an extended reach, to offer more set up flexibility.
Product Description | StarTech.com USB C Multiport Adapter, Dual HDMI Video, 4K 60Hz, 2-Port 10Gbps USB-A/USB-C 3.1 Hub, 100W USB Power Delivery Charging, GbE, SD, USB Type-C Mini Travel Dock, 12"/30cm Cable - Laptop Docking Station (102B-USBC-MULTIPORT) - docking station - USB-C / USB4 / Thunderbolt 3 / Thunderbolt 4 - 2 x HDMI - GigE | Product Type | Docking station | Docking Interface | USB-C / USB4 / Thunderbolt 3 / Thunderbolt 4 | Video Interfaces | 2 x HDMI | Dimensions (WxDxH) | 9.5 cm x 9.5 cm x 1.7 cm | Weight | 250 g | Colour | Space grey | Networking | Gigabit Ethernet | Manufacturer Warranty | 3-year warranty |
General | |
Width | 9.5 cm |
Depth | 9.5 cm |
Height | 1.7 cm |
Weight | 250 g |
Enclosure Colour | Space grey |
Video | |
Max Resolution Details | 4096 x 2160 - 60 Hz (Dual Display) |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | Power Delivery 3.0, USB 3.2 Gen 2, Battery Charging 1.2, USB4 |
Expansion / Connectivity | |
Expansion Slots | 1 (total) / 1 (free) x SD / MMC Memory Card |
Interfaces | 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB 3.2 Gen 2 with Battery Charging 1.2 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C |
Miscellaneous | |
Input Device | SD card reader |
Cables Included | 1 x USB-C cable - integrated - 30 cm |
Features | Wake on LAN, Preboot Execution Environment (PXE) support, full duplex support, DisplayLink DL-6950 chipset, Fast Role Swap, USB-C powered, plastic housing, HDR10 support, 100W power delivery (pass-through), 20W power consumption, up to 10Gbps data transfer |
Compliant Standards | RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol), Thunderbolt 3, Thunderbolt 4, DisplayLink certified |
System Requirements | |
OS Required | Android, Google Chrome OS, Ubuntu Linux 18.04, Apple macOS 11.0, Ubuntu Linux 20.04, Apple macOS 10.14 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 10.11 - 10.12, Apple macOS 12.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.5 cm |
Shipping Depth | 14.5 cm |
Shipping Height | 4.2 cm |
Shipping Weight | 400 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
