This USB Type-C Multiport Adapter with DP 1.4 Alternative Mode, DSC and MST, supports dual-HDMI (HDR) video with resolutions of up to 4K 60Hz uncompressed video. The mini travel dock turns your Dell XPS, Lenovo X1 Carbon, HP Elite/ProBook, or other USB-C laptop into a workstation, anywhere you go. The USB-C docking station provides dual HDMI outputs, a 2-port USB 3.2 Gen 1 Type-A (5Gbps) Hub including a BC 1.2 port to power and charge a USB peripheral, SD and MicroSD card readers, and a Gigabit Ethernet port, all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. In addition, it offers advanced charging through USB Power Delivery (PD) 3.0 pass-through via an integrated 12-inch (30 cm) USB-C host cable, for more set up flexibility.
Product Description | StarTech.com USB C Multiport Adapter, Dual HDMI Video, 4K 60Hz, 2-Port 5Gbps USB-A Hub, 100W Power Delivery Charging, GbE, SD/MicroSD, USB Type-C Mini Travel Dock, 12"/30cm Cable - USB C Laptop Docking Station - docking station - USB-C / Thunderbolt 3 / Thunderbolt 4 - 2 x HDMI - GigE | Product Type | Docking station | Docking Interface | USB-C / Thunderbolt 3 / Thunderbolt 4 | Video Interfaces | 2 x HDMI | Dimensions (WxDxH) | 14.5 cm x 5.9 cm x 1.4 cm | Weight | 165 g | Colour | Space grey | Networking | Gigabit Ethernet | Manufacturer Warranty | 3-year warranty |
General | |
Width | 14.5 cm |
Depth | 5.9 cm |
Height | 1.4 cm |
Weight | 165 g |
Enclosure Colour | Space grey |
Video | |
Max Resolution Details | 3840 x 2160 - 60 Hz (Dual Display) |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | USB 3.1, USB 3.2 Gen 1 |
Expansion / Connectivity | |
Expansion Slots | 1 (total) / 1 (free) x SD Memory Card , 1 (total) / 1 (free) x microSD |
Interfaces | 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C |
Miscellaneous | |
Input Device | SD card reader, microSD card reader |
Cables Included | 1 x USB-C cable - integrated - 30 cm |
Features | Wake on LAN, LED indicator, dual display support, full duplex support, MST (multi-stream transport), DisplayPort Alt Mode, Fast Role Swap, HDR10 support, 100W power delivery (pass-through) |
Compliant Standards | RoHS, WEEE, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.4, UASP (USB Attached SCSI Protocol), DSC, USB Power Delivery 3.0 |
System Requirements | |
OS Required | Google Chrome OS, Microsoft Windows 7 / 8 / 8.1 / 10 / 11 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 17 cm |
Shipping Depth | 14.2 cm |
Shipping Height | 3 cm |
Shipping Weight | 165 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
