StarTech.com USB-C Multiport Adapter 2xDP
£115.54
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Portable USB-C multiport adapter with flexible DisplayPort dual-monitor or single-monitor video outputs: dual 4K 30Hz, dual 2K 60Hz or single 4K60Hz
  • Power both the adapter and your laptop with 100W Power Delivery 3.0 (85W laptop charging) using a USB Type-C power adapter
  • Connect your devices with 2x USB-A ports - 1x USB 3.0/2.0 and 1x USB 2.0
  • Type: Docking
  • Stock Status: In Stock
Product codes
This USB-C multiport adapter turns your Windows laptop into a portable workstation. The USB-C to dual Display Port adapter connects your USB-C laptop to two DisplayPort monitors, letting you power through work faster or make presentations with different views on two displays. It gives you two USB-A ports, a Gigabit Ethernet port, a DP Alt Mode Switch, and laptop charging.
Through 100W?Power Delivery?3.0,?the?USB Type-C to DisplayPort adapter powers itself as well as your laptop and any attached peripherals, with up to 85W laptop charging when connected to a USB-C power adapter.?PD?3.0 features Fast Role Swap to prevent USB data disruption when?you?unplug?the power adapter to?switch?power sources (USB-C?power adapter to?bus power).
The USB-C video adapter extends your laptop screen to?dual DisplayPort displays. Using the DP Alt Mode switch, you can choose between higher display resolution or faster USB speed to meet your needs, for desktop or portable use. Choose between: dual 4K30 (or single 4K60) resolution with USB 2.0 speed, or dual 1080p (or single 4K30) resolution with USB 3.0 speed.
Product Description StarTech.com USB C Multiport Adapter - Dual 4K DP - Windows - 2xA - PD - docking station - 2 x DP
Product Type Docking station
Docking Interface USB-C
Video Interfaces 2 x DP
Dimensions (WxDxH) 6 cm x 12 cm x 1.18 cm
Weight 200 g
Colour Black
Networking Gigabit Ethernet
Designed For P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C Mul...
£115.54
