StarTech.com USB C Multiport Adapter 4K
£72.04
12 in stock
Delivery:
Standard: 1-3 working days
Product codes
This USB-C multiport adapter with HDMI turns your MacBook Pro, Dell XPS, or other USB-C laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, two USB 3.2 Gen 2 Type-A (10Gbps) ports, and a USB Type-C port (power/data), all through one connection to your laptop's USB-C or Thunderbolt 3 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 12-inch (30 cm) host cable for an extended reach to offer more set up flexibility.
The portable docking station connects your laptop to a 4K 30Hz HDMI monitor (3840 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
The USB-C to USB 3.2 Gen 1 hub gives you two USB-A ports one and a USB-C port (shared power/data) to connect your latest and legacy USB devices.
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards.
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
Product Description StarTech.com USB C Multiport Adapter, USB-C to 4K 60Hz HDMI 2.0, 100W Power Delivery Pass-through, SD/MicroSD, 2-Port USB 3.0 Hub, GbE, USB Type-C Mini Dock, 12" (30cm) Long Attached Cable - Works w/Thunderbolt 3 (DKT30CHSDPD1) - docking station - USB-C / Thunderbolt 3 - HDMI - GigE
Product Type Docking station
Docking Interface USB-C / Thunderbolt 3
Video Interfaces HDMI
Dimensions (WxDxH) 35.2 cm x 3.4 cm x 1.4 cm
Weight 99 g
Colour Black, space grey
Networking Gigabit Ethernet
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£72.04
