StarTech.com USB C Multiport Adapter
£85.84
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • 6-IN-1 USB-C MULTIPORT ADAPTER: Compact USB-C adapter w/ DP 1.4 Alt-Mode up to 4K 60Hz (4K 30Hz w/DP 1.2) HDMI 2.0b or Mini DisplayPort video; 4-Port 10Gbps USB Hub (USB 3.2/3.1 Gen 2): 3x USB-A w/ 1x BC 1.2 charging, 2x USB-C (1x PD Passthrough, 1x data)
  • EXTRA LONG CABLE: Portable USB Type-C multiport adapter dongle w/ 12" (30cm) attached cable for extended reach to reduce port/connector strain on 2-in-1 devices like Surface Pro 7, iPad Pro, HP Elite & laptops on risers; Works with USB4, Thunderbolt 3 & 4
  • RELIABLE PERFORMANCE: USB bus powered or via external USB-C power adapter; 100W Power Delivery 3.0 pass through w/ 15W reserved for adapter to avoid video flickering, device dropouts or overdrawing power common in other hubs; up to 85W for laptop charging
  • WIDE COMPATIBILITY: USBC mini dock works w/ USB-C laptops, ultrabooks & Chromebooks, plus TB3 laptops like HP, Dell XPS 13 9310, Lenovo X1 Carbon 9th Gen, MacBooks (Intel processor & M1 chip), Surface Laptop 4; Windows, macOS, iPadOS, Android & Chrome OS
  • 4K 60HZ WITH DP 1.4 ALT-MODE: Supports 4K 60Hz on host devices that support DP 1.4 Alt-Mode (min. Intel 11th Gen); on host devices that support DP 1.2 Alt-Mode, maximum video resolution is 4K 30Hz; works w/ DisplayPort monitors using a mDP to DP cable
  • PORTABLE & COMPACT: All-in-one USB-C multiport adapter dongle is made from durable aluminum & designed for transport in a laptop bag for easy on-the-go use between office, home office, shared office spaces, and business travel; works w/ 5Gbps USBC ports
Product codes
USB-C Multiport Adapter - HDMI & Mini DisplayPort Video - 100W PD Pass-Through - 4-Port USB Hub.
Product Description StarTech.com USB C Multiport Adapter, USB-C to HDMI or Mini DisplayPort 4K 60Hz, 100W Power Delivery Pass-Through, 4-Port 10Gbps USB Hub, USB Type-C Mini Dock, 12"/30cm Long Attached Cable - Works w/ Thunderbolt 3 (DKT31CMDPHPD) - docking station - USB-C / Thunderbolt 3 - HDMI, Mini DP
Product Type Docking station
Docking Interface USB-C / Thunderbolt 3
Video Interfaces HDMI, Mini DP
Weight 84.3 g
Power Power Provided
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£85.84
