StarTech.com USB C Multiport Adapter
£61.99
Delivery:
Standard: 1-3 working days
Key features
  • Expand the connectivity of your MacBook Pro, Chromebook, Dell XPS, or other USB-C enabled laptop
  • Power both the multiport adapter and your laptop with up to 100W Power Delivery, using your laptop’s USB-C based power adapter (supports USB PD 2.0)
  • Supports 4K Ultra HD HDMI (4096 x 2160p or 3840 x 2160p), one USB 3.0 port, a Gigabit Ethernet port and an SD card reader
  • Type: Cable
  • Stock Status: In Stock
Product codes
Expand the connectivity of your Thunderbolt 3/USB-C port enabled laptop. Compatible with Mac and Windows, this universal USB-C multiport adapter lets you turn your laptop into a powerful workstation, anywhere you go. The USB-C adapter provides a 4K Ultra HD HDMI video output, an ultra high-speed SD 4.0 card reader (with UHS-II support), a USB 3.0 Type-A port and one Gigabit Ethernet port, through your laptop's USB-C port. Plus, the adapter supports USB Power Delivery 2.0, so you can power the adapter and your laptop at the same time using a USB Type-C power adapter.
Product Description StarTech.com USB C Multiport Adapter - 4K HDMI - SD / SDHC / SDXC - Power Delivery (USB PD) - USB-C to USB Adapter - USB Type C Adapter (DKT3CHSD4GPD) - docking station - HDMI
Product Type Docking station
Docking Interface USB-C
Video Interfaces HDMI
Dimensions (WxDxH) 11 cm x 5 cm x 1.8 cm
Weight 100 g
Colour White, silver
Networking Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB C Mul...
£61.99
