StarTech.com USB-C Multiport Adapter Docking Station
£112.26
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Portable USB-C multiport adapter with flexible HDMI dual monitor or single monitor video outputs: dual 4K 30Hz, dual 2K 60Hz or single 4K60Hz
  • Power both the adapter and your laptop with 100W Power Delivery 3.0 (85W laptop charging) using a USB-C power adapter
  • Connect your devices with 2x USB-A ports - 1x USB 3.0/2.0 and 1x USB 2.0
  • Device Type: Laptop
  • Type: Docking Stations
  • Device Screen Size: [N/A]
  • Colour: Black
  • Stock Status: In Stock
Product codes
This USB-C multiport adapter turns your Windows laptop into a portable workstation. The dual HDMI adapter connects your USB-C laptop to two HDMI monitors, letting you power through work faster or make presentations with different views on two displays. It gives you two USB-A ports, a Gigabit Ethernet port, a DP Alt Mode Switch, and laptop charging.
Through 100W Power Delivery 3.0, the USB Type-C multiport adapter powers itself as well as your laptop and any attached peripherals, with up to 85W laptop charging when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you unplug the power adapter to switch power sources (USB-C power adapter to bus power).
The USB-C HDMI multiport adapter extends your laptop screen to dual HDMI displays. Using the DP Alt Mode switch, you can choose between higher display resolution or faster USB speed to meet your needs, for desktop or portable use. Choose between: dual 4K30 (or single 4K60) resolution with USB 2.0 speed, or dual 1080p (or single 4K30) resolution with USB 3.0 speed.
The USB-C display adapter gives you two USB-A ports (one USB 3.0/USB 2.0 port, and one USB 2.0) to connect your mouse, keyboard or other peripherals.
The GbE port ensures reliable wired network access. A 1 m USB-C cable is included for greater flexibility.
Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
Product Description StarTech.com USB C Dock - 4K Dual Monitor HDMI USB-C Docking Station - 100W Power Delivery Passthrough, GbE, 2x USB-A - Multiport Adapter - docking station - 2 x HDMI
Product Type Docking station
Docking Interface USB-C
Video Interfaces 2 x HDMI
Dimensions (WxDxH) 6 cm x 12 cm x 1.88 cm
Weight 200 g
Colour Black
Networking Gigabit Ethernet
Designed For P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C Mul...
£112.26
