StarTech.com USB-C Multiport Adapter HDMI
£75.46
43 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 5-IN-1 MULTIPORT ADAPTER: USB-C multiport adapter with DP 1.4 Alt-Mode up to 4K 60Hz (4K 30Hz with DP 1.2) HDMI 2.0b (HDR10) video; 4-Port USB Hub 5Gbps: 3x USB-A (USB 3.2/3.1 Gen 1) with 1x BC 1.2 charging, 1x USB-C (100W PD Passthrough)
  • EXTRA LONG CABLE: USB C to HDMI multiport adapter with 12" (30cm) attached cable for extended reach to reduce port/connector strain on 2-in-1 devices like Surface Pro 7, iPad Pro, HP Elite x2 & laptops on riser stands
  • PORTABLE & COMPACT: Portable all-in-one USB Type-C multiport adapter is made from durable aluminum & designed for easy transport in a laptop bag for convenient on-the-go use between office, home office, shared office spaces, and business travel
  • RELIABLE PERFORMANCE: USB bus powered or via external USB-C power adapter; 100W Power Delivery 3.0 pass through w/ 12W reserved for adapter to avoid video flickering, device dropouts or overdrawing power common in other hubs; up to 88W for laptop charging
  • WIDE COMPATIBILITY: Compatible with USB-C laptops, ultrabooks & Chromebooks, plus Thunderbolt 3 laptops from HP, Dell, Lenovo, MacBooks (Intel processor & M1 chip), and Surface Laptop 4; USBC mini dock works w/ Windows, macOS, iPadOS, Android & Chrome OS
  • 4K 60HZ WITH DP 1.4 ALT-MODE: Supports 4K 60Hz on host devices that support DP 1.4 Alt-Mode (min. Intel 11th Gen); on host devices that support DP 1.2 Alt-Mode, maximum video output resolution is 4K 30Hz; works w/ ultra-wide monitors up to 3440x1440@60Hz
Product codes
USB-C Multiport Adapter - 4k 60Hz HDMI 2.0b - 100W Power Delivery Passthrough - 4-Port USB Hub.
Product Description StarTech.com USB C Multiport Adapter, USB-C to HDMI 2.0b 4K 60Hz (HDR10), 100W Power Delivery Pass-Through, 4-Port 5Gbps USB 3.0 Hub, USB Type-C Mini Dock, with 12" (30cm) Attached Cable - Thunderbolt 3 Compatible (DKT30CHPD3) - docking station - USB-C - HDMI
Product Type Docking station
Docking Interface USB-C
Video Interfaces HDMI
Dimensions (WxDxH) 4.5 cm x 3 cm x 1.3 cm
Weight 93 g
Colour Black & grey
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£75.46
