StarTech.com USB-C Multiport Adapter w/HDMI or VGA w/100W PD
£78.49
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect an HDMI or VGA monitor to your host device with this USB-C multiport adapter
  • Extended length 30cm attached host cable for more flexible connectivity, plus plug-and-play setup
  • Supports 100W Power Delivery 3.0 and PD passthrough to power both the multiport adapter and your laptop, using your laptop's USB-C power adapter
  • Provides ports for USB peripherals when travelling with 2x USB 3.0 Type A and 1x USB 3.0 Type-C ports
  • USB Type-C multiport adapter also includes SD/Micro SD card reader, 3.5mm 4-position audio and Gigabit Ethernet ports
  • Ideal for portability, travel and creating small workstations
  • Stock Status: In Stock
Product codes
USB-C Mini Dock 100W PD Passthrough USB-C & A Ports SD Card Reader Mac, Windows & ChromeOS Android OS GbE. This USB-C multiport adapter turns your MacBook Pro, USB-C laptop, Chromebook or Android (Samsung Galaxy S8, Note 9 and above) device into a workstation, anywhere you go. A USB Type-C adapter, ideal for travel, features everything from the essential HDMI or VGA video outputs and USB ports to an SD card reader and 100W PD including PD passthrough. All through a single extended length 30 cm Thunderbolt 3 or USB-C attached host cable, providing more flexibility for harder to reach laptop and tablet connections.
Two Video Output Options with HDMI or VGA
This USB-C multiport adapter features both an HDMI and VGA port providing you with two single video output options for your boardroom presentations or your workstation setup including support for an ultra-wide monitor.
Power & Charge with 100W Power Delivery 3.0
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. The USB-C hub features PD passthrough so you can use your laptop's own charger to power the hub (requires 15W) and power or charge your laptop simultaneously.
All the Essential Ports with USB
The USB-C to USB 3.0 hub gives you one USB-C port (power & data) and two USB-A ports to connect your latest and legacy USB devices.
Includes Ports to Do More with SD, Audio & Gigabit Ethernet
Access your multimedia content, audio, and network with ease. The multiport adapter provides direct access to your:
SD, SDHC and SDXC memory cards or microSD cards via the SD card slot
Audio content via headphones or microphone through the 3.5mm 4- position audio port
Ethernet network via the GbE port using a hard-wired connection
DKT30CHVAUSP is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Product Description StarTech.com USB C Multiport Adapter - USB-C Mini Travel Dock w/ 4K HDMI or 1080p VGA - 100W PD, 3x USB, SD, GbE, Audio - Laptop/Tablet - docking station - VGA, HDMI
Product Type Docking station
Docking Interface USB-C
Video Interfaces VGA, HDMI
Dimensions (WxDxH) 6 cm x 11.6 cm x 1.5 cm
Weight 114 g
Colour Black, space grey
Networking Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C Mul...
£78.49
