High Dynamic Range Aluminum 6" (15.24 cm) Built-In Cable. This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to an HDMI or DisplayPort display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Two-in-One Video Connectivity with Travel in Mind
Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. The multiport adapter features both HDMI and DisplayPort outputs, so you can conveniently connect your laptop to any HDMI or DP-equipped display, using this multiport adapter.
The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
Astonishing 4K Picture Quality and HDR
The HDMI and DisplayPort outputs on this USB-C video adapter lets you harness the audio and video capabilities that are built into your computer's USB-C connection, delivering the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
Stylish Connectivity for Your MacBook, MacBook Pro, or Any Laptop
The USB C display adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
CDP2DPHD is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Note: This adapter only supports a single display - you are not able to output DisplayPort and HDMI video simultaneously.
Product Description | StarTech.com USB C Multiport Video Adapter, 4K 60Hz USB-C to HDMI 2.0 or DisplayPort 1.2 Monitor Adapter, USB Type-C 2-in-1 Display Converter HDMI/DP HBR2 HDR, Thunderbolt 3 Compatible - USB-C 2 in 1 Adapter (CDP2DPHD) - adapter - DisplayPort / HDMI - 20.5 cm | Cable | Adapter - DisplayPort / HDMI | Max Output Resolution | 3840 x 2160 - 60 Hz | Length | 20.5 cm | Colour | Space grey | Connectors | 24 pin USB-C - male (input) | Connectors (Second End) | HDMI - female (output) , DisplayPort - female (output) | Compliant Standards | Displayport 1.2/Thunderbolt 3 | Features | 4K support, active adapter | Manufacturer Warranty | 3-year warranty |
General | |
Cable Type | Adapter 4K support, active |
Interface Supported | DisplayPort / HDMI |
Jacket Material | Aluminium |
Length | 20.5 cm |
Features | HDR support, HBR2 audio support, multi-channel audio, DisplayPort Alternate Mode support, Parade PS8338 chipset, ITE Tech IT6563 chipset |
Adapters & Converters | |
Max Output Resolution | 3840 x 2160 |
Refresh Rate | 60 Hz |
Connectivity | |
Connectors (Second End) | 19 pin HDMI Type A - female (output) , 20 pin DisplayPort - female (output) |
Miscellaneous | |
Compliant Standards | FCC, RoHS, WEEE, REACH, RCM |
Dimensions & Weight | |
Width | 6.2 cm |
Height | 1.5 cm |
Weight | 48 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 17.3 cm |
Shipping Depth | 8 cm |
Shipping Height | 2 cm |
Shipping Weight | 70 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
