StarTech.com USB-C to 2x HDMI MST Splitter
£70.54
2 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Maximize your productivity by connecting two displays to your computer using the dual-monitor adapter
  • MST technology uses your existing video card to minimize the use of system resources
  • USB-C hub supports Ultra HD resolutions up to 4K
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Connect two independent displays to a single USB Type-C port. This MST hub lets you connect two HDMI monitors to your USB-C computer. MST works on any Windows device that supports DP Alt Mode over USB Type-C, such as models of Dell Precision and Dell XPS laptops and ASUS ROG GL752. The MST hub also works with Thunderbolt 3 ports to provide Thunderbolt 3 to dual HDMI conversion.
The USB-C HDMI hub is powered by the USB-C port, so you don't require an additional power adapter. This adapter works with USB Type-C devices that pass a DisplayPort video signal.
The newest generations of laptops are more portable than ever. But, this could mean that you're left with fewer video outputs and confined to your laptop's integrated screen. This USB-C MST hub solves these problems by letting you connect two independent HDMI displays through a USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity - perfect for creating a hot-desk solution with a wireless keyboard and mouse peripheral set.
The hub also lets you mirror the same image onto multiple displays, for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and offers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, it's perfect for all high-resolution applications such as graphic design and CAD drawing.
Your USB-C equipped device must support video (DP Alt Mode) to work with this adapter.
MST shares 21.6Gbps across all attached displays. Higher resolutions can restrict the available bandwidth with the remaining ports.
Product Description StarTech.com 2-Port USB-C to HDMI MST Hub – 4K 30Hz – Dual Monitor Video Splitter – Windows and Thunderbolt 3 Compatible (MSTCDP122HD) - external video adapter - black
Device Type External video adapter
Bus Type USB-C
Max Resolution 3840 x 2160
Interfaces 2 x HDMI
Enclosure Colour Black
Designed For P/N: TB33A1C
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: CT5J 042114
£36.93
product
Ref: CT5J 042114
Accessories
Packaging
Functional
Software
Manuals
£36.93
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C to...
£70.54
