StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Ad...
StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter
£26.31
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High Bit Rate 3 (HBR3) capabilities, providing bandwidths up to 32.4Gbps
  • Cutting-edge video quality with support for UHD video resolutions up to 8K 30Hz
  • Supports HDR for expanded contrast ratio and color accuracy
  • Interface: USB-C
  • Stock Status: In Stock
Product codes
This USB-C to DisplayPort adapter lets you connect your USB Type-C or Thunderbolt 3 device to a DisplayPort monitor or display, providing you with a convenient, high-performance solution. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Supporting four times the resolution of 4K, this 8K DisplayPort 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
With cutting-edge picture quality, this adapter is ideal for: Displaying crisp digital signage walls; Creating eye-catching visuals for photography and videography; Streaming high-resolution, life-like content.
The DisplayPort dongle is also backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
This lightweight display adapter is highly portable, with a small-footprint design. It's the perfect accessory for your MacBook, Microsoft Surface Book or other USB-C (or Thunderbolt 3) device, fitting perfectly into your carrying case.
To ensure easy operation, this USB C to DisplayPort adapter supports plug-and-play installation, removing the need for additional software or drivers.
Your USB-C device must support DP Alt Mode to work with this adapter. This product will not work with the Samsung S8 smartphone. For hassle-free compatibility with the S8 use CDP2DP.
Product Description StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter - Thunderbolt 3 - Video Dongle for DP 1.4 Monitor & Display - external video adapter - black
Device Type External video adapter
Bus Type USB-C
Max Resolution 7680 x 4320
Interfaces DisplayPort (female connector)
Dimensions (WxDxH) 6 cm x 2.35 cm x 1.5 cm
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB C to...
£26.31
