StarTech.com USB C to DisplayPort Adapter - Power Delivery -...
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz
£35.32
Delivery:
Standard: 1-3 working days
Key features
  • High Bit Rate 3 (HBR3) capabilities, providing bandwidths up to 32.4Gbps
  • Cutting-edge video quality with support for UHD video resolutions up to 8K 30 Hz
  • Charge your USB-C device while connecting a DisplayPort display with 60W power delivery
  • Stock Status: In Stock
Product codes
This USB-C to DisplayPort adapter lets you connect your USB Type-C or Thunderbolt 3 device to a DisplayPort display, providing you with a convenient, high-performance solution. The adapter features USB Power Delivery so you can power and charge your devices while outputting Ultra HD video.
Product Description StarTech.com USB C to DisplayPort Adapter with Power Delivery, 8K 60Hz/4K 120Hz USB Type C to DP 1.4 Monitor Video Converter w/60W PD Pass-Through Charging, HBR3, Thunderbolt 3 Compatible - USB-C Male to DP Female (CDP2DP14UCPB) - USB / DisplayPort adapter
Type USB / DisplayPort adapter
Features 8K support, active adapter, up to 60 Watts of power delivery, High Bit Rate 3 (HBR3), 7.1 audio channel support
Connectors 24 pin USB-C - male (input)
Connectors (Second End) 20 pin DisplayPort - female (output) , 24 pin USB-C - female (output)
Compliant Standards Thunderbolt 3 / DisplayPort 1.4
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£35.32
