StarTech.com USB-C to DisplayPort MST Hub - 2-Port
£67.99
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Maximize your productivity by connecting two displays to your computer using the MST dual-monitor video splitter
  • MST technology uses your existing video card to minimize the use of system resources
  • Supports Ultra HD resolutions up to 4K
  • Stock Status: In Stock
Product codes
Use this adapter to connect two independent displays to a single USB Type-C port. This MST hub lets you connect two DisplayPort monitors to your USB-C computer. MST works on any Windows device with DP alt mode over USB Type-C, such as models of Dell Precision and Dell XPS laptops. The MST hub is powered by the USB-C port, so you don't require an additional power adapter.
This adapter works with USB Type-C devices that pass a DisplayPort video signal and it's also compatible with Thunderbolt 3 ports.
The newest generations of laptops are more portable than ever. Unfortunately, this could mean that you're left with fewer video outputs and confined to a small integrated screen. This MST hub solves these problems by letting you connect two independent displays to a USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity - perfect for creating an easy-to-dock hot-desk solution with a wireless keyboard and mouse peripheral set.
The hub also lets you mirror the same image onto multiple displays, for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and offers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, the MST hub is perfect for all high-resolution applications such as graphic design and CAD drawing.
With this MST hub, you can use separate DP video adapters to connect HDMI, VGA or DVI displays, for compatibility with all of your existing monitors. The hub supports DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Product Description StarTech.com 2-Port Multi Monitor Adapter - USB-C to DisplayPort 1.2 Video Splitter - USB-C to Dual DP MST Hub - TB3 Compatible - Windows - external video adapter
Device Type External video adapter
Bus Type USB-C
Max Resolution 3840 x 2160
Interfaces 2 x DisplayPort , USB-C (male connector)
Designed For P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C to...
£67.99
