StarTech.com USB-C to DVI Adapter - White
£24.28
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Hassle-free connection with the reversible USB-C connector
  • Maximum portability with a small footprint and a lightweight design
  • Thunderbolt 3 port compatible
Product codes
Connect your MacBook, Chromebook or laptop with USB-C to a DVI monitor or projector. This USB-C to DVI adapter lets you output DVI video from a USB Type-C device such as a MacBook, Chromebook or Dell XPS laptop. The adapter works with USB-C devices that pass a DisplayPort video signal and it's also compatible with Thunderbolt 3 ports.
This USB Type-C video adapter is highly portable, with a small footprint and a lightweight design. It's the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
The adapter supports dual-link video resolutions up to 2560x1600. You'll be surprised at the picture quality the adapter provides, even when connected to a DVI monitor, projector or television. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning resolution.
This adapter lets you enjoy the versatility of your portable device's USB Type-C port. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work.
The CDP2DVIW features a white housing that looks great with your MacBook.
Your USB-C equipped device must support video to work with this adapter. Some legacy DVI monitors may be limited to a resolution of 1920x1200 when used with this adapter.
StarTech.com USB C to DVI Adapter USB Type C DVI Video Converter White - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
2560 x 1600
DVI-I
Enclosure Colour
White
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C to...
£24.28
