StarTech.com USB-C to Ethernet Adapter
£30.22
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • ADDED CONNECTIVITY: This USB-C to RJ45 adapter adds an Ethernet port to your computer enabling Gigabit speeds. This USB C to Ethernet adapter is the ideal small and lightweight companion for new computers that are not equipped with an Ethernet port
  • OS COMPATIBILITY: The USB-C to LAN adapter for laptops offers plug-and-play connectivity and is widely supported by Windows, macOS, and Linux. Other supported mobile platforms include ChromeOS, Android, and iPadOS
  • ETHERNET DONGLE: The Gigabit network adapter offers compatibility with 10/100/1000 Mbps networks, durable construction, wake-on-LAN, 9K jumbo frames, and driverless installation, making it an ideal solution for rapid deployment
  • VERSATILE DESIGN: The USB-C to RJ45 dongle has an extended built-in 11.8in/30cm cable, providing additional reach and flexibility while reducing cable/connector strain. The USB-C NIC is conveniently powered via the USB Type-C port
  • SPECIFICATIONS: 1x USB 3.0/3.2 Gen1 Type-C 5 Gbps Port | 1x RJ45 Port | 3 Speeds 10/100/1000 Mbps | ASIX AX88179A | 9K Jumbo Frames | VLAN Tagging | Wake-on-LAN | Energy Efficient Ethernet | USB Powered | Backed for 2 years | 24x5 Free Lifetime Assistance
  • Wired / Wireless: Wired
  • Protocol: Fast Ethernet, Gigabit Ethernet, Ethernet
  • Type: Network adapter
Product codes
Add a Gigabit network port to your computer, using a USB Type-C connection. The RJ45 port supports multiple speeds (10/100/1000 Mbps) and is fully compatible with Cat5 [and higher] cabling. This is an essential peripheral for new laptops that lack an Ethernet port. In addition, it can be utilized or whenever WiFi is unavailable or when wireless network speeds are inconsistent.
Product Description StarTech.com USB-C to Ethernet Adapter, 10/100/1000 Mbps, Gigabit Network Adapter w/ ASIX AX88179A Chip, 1ft/30cm Cable, USB Type C to RJ45 Ethernet Dongle, USB C to LAN Adapter, Windows/macOS/Linux/ChromeOS (US1GC30B2) - network adapter - USB-C - Gigabit Ethernet x 1
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB-C
Ports Gigabit Ethernet x 1
Dimensions (WxDxH) 17.4 cm x 2.7 cm x 1.6 cm
Weight 23 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 5 Gbps
Capacity Jumbo frame size: 9000
Processor ASIX AX88179A
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3az, USB 3.2 Gen 1
Colour Grey
System Requirements Android, Google Chrome OS, Microsoft Windows Server 2019, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Apple macOS 12, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Linux 2.6.13
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£30.22
