Using a single USB Type-C port on your laptop, output HDMI video and charge the laptop. This USB-C to HDMI adapter lets you connect your laptop or MacBook with USB Type-C to an HDMI display. The video adapter features USB Power Delivery, which enables you to power your laptop while you're outputting video to an HDMI display.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel. It's also compatible with Thunderbolt 3 ports.
Unlike some video adapters that take up your laptop's USB-C charge port while you're outputting video and prevent you from charging your computer, this video adapter supports USB Power Delivery and features an additional USB-C port. This means you can charge your laptop, even while outputting video, by simply connecting the laptop's power adapter to the additional port. It's the perfect solution for laptops that only have a single USB-C port.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your MacBook or Chromebook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always connect, saving you the hassle and embarrassment of struggling with your device when you're trying to deliver a presentation or sharing information.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. The adapter lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display. 4K resolution gives you additional screen space to simplify your approach to detailed work such as editing video and viewing large spreadsheets.
Even if you're not running 4K, the adapter supports high-definition 1080p and lower resolutions, which gives you peace of mind in knowing that this adapter will comfortably work with any HDMI video display you come across.
Product Description | StarTech.com USB C to HDMI 2.0 Adapter with Power Delivery, 4K 60Hz USB Type-C to HDMI Display/Monitor Video Converter, 60W PD Pass-Through Charging Port, Thunderbolt 3 Compatible, Black - USB-C Display Adapter (CDP2HDUCP) - adapter - HDMI / USB | Cable | Adapter - HDMI / USB | Max Output Resolution | 4096 x 2160 - 60 Hz | Colour | Black | Connectors | USB-C - male (input) | Connectors (Second End) | HDMI - female (output) , USB-C (power only) - female | Compliant Standards | Displayport 1.2/Thunderbolt 3 | Features | USB Power Delivery (60W), 4K60Hz (4096 x 2160) support | Manufacturer Warranty | 3-year warranty |
General | |
Cable Type | Adapter USB Power Delivery (60W), 4K60Hz (4096 x 2160) support |
Interface Supported | HDMI / USB |
Features | DisplayPort Alternate Mode support, 7.1 channel Surround Sound |
Colour | Black |
Adapters & Converters | |
Max Output Resolution | 4096 x 2160 |
Refresh Rate | 60 Hz |
OS Required | Apple MacOS, Linux, Microsoft Windows, Google Chrome OS, Apple iPadOS |
Connectivity | |
Connectors | 24 pin USB-C - male (input) |
Connectors (Second End) | 19 pin HDMI Type A - female (output) , 24 pin USB-C (power only) - female |
Miscellaneous | |
Compliant Standards | FCC, RoHS, HDCP 2.2, HDCP 1.4, USB Power Delivery |
Dimensions & Weight | |
Width | 3.3 cm |
Depth | 5 cm |
Height | 1.3 cm |
Weight | 24 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.6 cm |
Shipping Depth | 17.4 cm |
Shipping Height | 3.2 cm |
Shipping Weight | 106 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
