StarTech.com USB-C to Micro-USB Adapter M/F
£9.33
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Use your existing Micro-USB cables for charging and syncing your newer USB-C devices
  • Compact design fits nicely into any carrying case
  • Guaranteed reliability with a lifetime warranty
  • Stock Status: In Stock
Product codes
Connect your USB Type-C mobile device to a USB-A host, using a standard Micro-USB Cable. This USB-C to Micro-USB adapter lets you charge and sync USB Type-C mobile devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, using a Micro-USB cable.
Simply insert the adapter's USB-C connector into your mobile device. Then, plug your Micro-USB cable into the adapter's Micro-USB port and connect the cable to the USB-A port on your computer or USB-A wall charger.
The compact adapter is portable enough for carrying as a tablet or laptop accessory and it reduces the number of cables that you need to carry around with you in order to charge all of your mobile devices.
Product Description StarTech.com USB C to USB Micro B - USB Type C to USB M / F - USB 2.0 - USB C Connector - USB-C to USB Micro B Adapter (USB2CUBADP) - USB-C adapter
Type USB-C adapter
Connector 24 pin USB-C - male
Connector (Second End) 5 pin Micro-USB Type B - female
Compliant Standards USB / USB 2.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C to...
£9.33
