StarTech.com USB-C to Mini DisplayPort
£25.09
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Run resource-demanding applications on 4K displays
  • Hassle-free connection with the reversible USB-C connector
  • Thunderbolt 3 compatible
  • Audio support
Product codes
USB-C™ to Mini DisplayPort adapter lets you output mDP video and audio from the USB Type-C™ port on your laptop or other device. The adapter works with USB-C devices that pass a DisplayPort video signal (DP Alt Mode), such as your MacBook Pro, Chromebook™ or other USB-C laptop.
This versatile adapter enables you to connect a Mini DisplayPort monitor to your USB-C computer using a Mini DisplayPort cable, or re-purpose your existing mDP equipped workspace to work with your new USB-C computer.
StarTech.com USB C to Mini DisplayPort Adapter - USB C to Mini DP - 4K 60Hz - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
Mini DisplayPort
2.7 cm x 6 cm x 1.6 cm
Enclosure Colour
White
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB-C to...
£25.09
