StarTech.com USB C to RS232 Cable
£21.03
34 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Add a serial port with this USB C to serial with COM port retention. This USB-C to serial adapter lets you connect your USB-C devices to your legacy serial equipment. It converts a USB-C port on your laptop or computer into an RS232 DB9 serial port with COM port retention. This gives you a cost-saving and convenient way to connect to serial devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals.
The RS232 adapter cable is compatible with Windows, macOS and Linux operating systems, which makes it easy to integrate into mixed environments.
A time-saving and convenient USB/serial solution, the adapter retains assigned serial COM port values in nonvolatile memory, allowing the same values to automatically be re-assigned to the adapter serial port if disconnected and reconnected, or disconnected from one USB port and installed in another.
The USB-C serial cable also supports advanced features like remote wake-up and power management control.
Product Description StarTech.com USB C to Serial Adapter - with COM Port Retention - Windows / Mac / Linux - USB C to DB9 Cable - USB C to RS232 Cable (ICUSB232PROC) - USB / serial cable - 40 cm
Type USB / serial cable
Features Chipset Prolific PL2303RA
Length 40 cm
Connector 9 pin D-Sub (DB-9) - male
Connector (Second End) 24 pin USB-C - male
Compliant Standards USB / USB 2.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB C to...
£21.03
