StarTech.com USB C to SATA Adapter Cable
£48.50
Delivery:
Standard: 1-3 working days
Key features
  • Connect a 2.5”/3.5” SATA drive to your USB-C enabled laptop or desktop computer, for quick access to your external data
  • Fast data transfer rates through USB 3.1 Gen 2 (10Gbps)
  • Integrated 1 m cable, for convenient use
  • Stock Status: In Stock
Product codes
This USB-C to SATA adapter cable gives you fast and easy access to the data on your 2.5 in./3.5 in. solid-state drives and hard drives. The adapter cable lets you connect your USB-C enabled laptop or desktop computer directly to a SATA drive and access it through ultra-fast USB 3.1 Gen. 2 (up to 10Gbps). It's the ideal accessory for your Dell XPS, MacBook, Chromebook or other USB Type-C enabled device.
The USB-C to SATA adapter cable lets you quickly swap your drives. You can copy or retrieve data from your 2.5 in. or 3.5 in. SATA drive, with no additional accessories required.
The tool-free adapter cable is ideal for IT technicians who need fast access to SATA drives. It's the perfect solution for data migration, drive cloning, and data backup or recovery applications, providing the fast performance of USB 3.1 Gen 2. You can also operate multiple adapters at the same time, when you need simultaneous access to many drives.
USB 3.1 Gen 2 gives you greater bandwidth and speed, with rates of up to 10Gbps - twice the speed of USB 3.0 (also known as USB 3.1 Gen 1). It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
The compact, lightweight design of the USB-C to SATA adapter provides easy portability. The adapter features an integrated 1 m cable, so you never have to worry about forgetting to bring your connector cable with you.
You can connect easily to a 2.5 in. solid-state drive or hard drive, using USB power, with no external power required. A universal power adapter is included for use when connecting to your 3.5 in. drives or for any 2.5 in. drives that may require additional power.
Product Description StarTech.com USB C to SATA Adapter Cable - for 2.5 / 3.5" SATA Drives - 10Gbps - USB 3.1 - SATA to USB Adapter - External Hard Drive Cable (USB31C2SAT3) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
Device Type Storage controller - external
Bus Type USB 3.1 (Gen 2)
Colour Black
Hard Drive Form Factor Compatibility 2.5", 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive, solid state drive
Power AC 120/230 V
Dimensions (WxDxH) 2.5 cm x 8.7 cm x 2 cm
Weight 80 g
Designed For P/N: SVA12M2NEUA, SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£48.50
