This USB duplicator and eraser lets you clone or erase up to seven USB flash drives, without a host computer connection. This means you can work more efficiently and manage larger batches of USB drives, saving time and effort.
The standalone USB duplicator and eraser is perfect for IT professionals and system administrators in corporate, education, marketing, or sales environments.
Product Description | StarTech.com USB Duplicator - 1:7 - USB Flash Drives - Flash Drive Duplicator (USBDUPE17) - USB drive duplicator - TAA Compliant | Device Type | USB drive duplicator | Colour | Black | Max Supported Capacity | 2 TB | Installed Devices / Modules Qty | 7 (max) | Duplication Speed | 1.5 GBpm | Localisation | Australia, Japan, New Zealand, North America, United Kingdom, Europe | Built-in Devices | Status LCD | Power | AC 120/230 V | TAA Compliant | Yes | Dimensions (WxDxH) | 16 cm x 19 cm x 3.46 cm | Weight | 1 kg | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Colour | Black |
Chassis | |
Supported Devices / Modules Qty | 7 |
Storage | |
Expansion / Connectivity | |
Interfaces | 8 x USB 2.0 - 4 pin USB Type A |
Miscellaneous | |
Features | 8 LED indicators, Xilinx Spartan XC3S700A chipset, buffer 128 MB |
MTBF | 8760 hours |
Compliant Standards | FCC, RoHS, WEEE, RCM |
Power | |
Power Device | 1 x external power adapter |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 108 Watt |
Dimensions & Weight | |
Width | 16 cm |
Depth | 19 cm |
Height | 3.46 cm |
Weight | 1 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
