StarTech.com USB Stereo Audio Adapter External Sound Card
£13.59
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A compact and portable audio adapter that can instantly give a system audio capabilities without any software or driver installation
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
  • Interface: USB 2.0
  • Sound Output Mode: Stereo
  • Stock Status: In Stock
Product codes
Documents
Add headphone and MIC audio connectors through USB.
This USB Audio adapter converts a USB port to an audio port, allowing you to add headsets and microphones to your computer without the need to unplug other devices!
Compliant with USB 2.0 and USB audio device specification 1.0, the USB audio adapter couldn't be any simpler to install...it's as easy as connecting the adapter to an available USB 2.0 port, then connecting your audio devices to the provided 3.5 mm audio ports as needed.
Compatible with Windows 98SE and up, as well as Mac OS 9.x and later, the adapter integrates into any computer environment, providing superb sound quality and convenience that can't be matched.
Product Description StarTech.com USB Sound Card - 3.5mm Audio Adapter - External Sound Card - Black - External Sound Card (ICUSBAUDIOB) - sound card
Device Type Sound card
Enclosure Type External
Interface Type USB 2.0
Dimensions (WxDxH) 4 cm x 8 cm x 1.5 cm
Weight 54 g
Colour Black
Sound Output Mode Stereo
System Requirements Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 3.5 to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14
Resources
The following resources are available for the StarTech.com USB Stereo Audio Adapter External Sound Card
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB Stere...
£13.59
