StarTech.com USB Stereo Audio Adapter External Sound Card wit...
StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio
£25.03
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Add home-theater surround sound support with the integrated digital S/PDIF output
  • Replace an internal sound card easily with a compact external USB device
  • Adjust sound output easily with external volume and EQ controls
  • Interface: USB 2.0
  • Sound Output Mode: Stereo
  • Stock Status: In Stock
Product codes
Add an SPDIF digital audio output and standard 3.5mm audio/microphone connections to your system through USB. The ICUSBAUDIO2D External USB Sound Card lets you add an S/PDIF digital audio output and standard 3.5mm analog audio/microphone connections to your system through USB - a convenient way to bypass or replace an internal sound card without having to open the computer case.
For home-theater quality sound, the USB DAC (digital-to-analog converter) offers 96KHz / 24-bit sampling rates for both playback and recording, and a 3.5mm S/PDIF port with support for Dolby Digital 5.1 surround sound (AC3) and DTS pass-through (5.1 surround sound is supported in Windows only).
This versatile USB audio adapter features an integrated 3.5mm 4-position TRRS connection for your headphones or combination headset/microphone. Also a convenient external volume control for quick adjustments, a hardware EQ switch for Bass or Treble boosting, and an LED status bar to display the current sampling rate.
Product Description StarTech.com USB Stereo Audio Adapter External Sound Card w/ SPDIF Digital - sound card
Device Type Sound card
Enclosure Type External
Interface Type USB 2.0
Dimensions (WxDxH) 4.6 cm x 4.7 cm x 1.6 cm
Weight 36 g
Colour Black
Sound Output Mode Stereo
DAC Resolution 24-bit
Sample Rate 96 kHz (max)
System Requirements Linux, Apple MacOS X 10.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB Stere...
£25.03
