StarTech.com USB to DVI External Video Card Multi Monitor Ada...
StarTech.com USB to DVI External Video Card Multi Monitor Adapter – 1920x1200
£47.47
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Supports resolutions up to 1920 x 1200
  • Works with desktop and laptop computers
  • No power adapter required, easy installation
Product codes
The USB2DVIE3 USB DVI Video Adapter offers a perfect external multi-monitor solution, enabling you to add a high-resolution (up to 1920x1200) external DVI output to your desktop or laptop computer system using an available USB 2.0 port. A cost-effective solution for systems that lack the outputs required for a multi-monitor setup, this high-performance USB to DVI adapter can be used to mirror your primary display and show the same image on both screens, or extend your desktop to double your workspace. This small form factor USB video adapter can be used with up to 4 additional (5 total) USB2DVIE3 USB video adapters, creating multiple DVI connections to add additional displays quickly and easily - all without having to open the computer case to add extra video cards.
StarTech.com USB to DVI External Video Card Multi Monitor Adapter 1920x1200 - external video adapter - 32 MB - black
External video adapter
Bus Type
USB 2.0
32 MB SDRAM
Max Resolution
1920 x 1200
DVI-I (Single-Link) , VGA - with adapter
5.3 cm x 8.8 cm x 1.8 cm
Enclosure Colour
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB to DV...
£47.47
