StarTech.com USB to DVI External Video Card Multi Monitor Ada...
StarTech.com USB to DVI External Video Card Multi Monitor Adapter – 1920x1200
£47.47
26 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compact, USB powered adapter provides the easiest way add a high-resolution secondary or additional display to your PC
  • Completely external device offers a simple upgrade solution saving the cost and hassle of upgrading the internal video card on your system
  • The ability to use multiple adapters (up to five) provides a scalable display configuration for future expansion
  • Stock Status: In Stock
Product codes
The USB2DVIE3 USB DVI Video Adapter offers a perfect external multi-monitor solution, enabling you to add a high-resolution (up to 1920x1200) external DVI output to your desktop or laptop computer system using an available USB 2.0 port. A cost-effective solution for systems that lack the outputs required for a multi-monitor setup, this high-performance USB to DVI adapter can be used to mirror your primary display and show the same image on both screens, or extend your desktop to double your workspace. This small form factor USB video adapter can be used with up to 4 additional (5 total) USB2DVIE3 USB video adapters, creating multiple DVI connections to add additional displays quickly and easily - all without having to open the computer case to add extra video cards.
Product Description StarTech.com USB to DVI External Video Card Multi Monitor Adapter 1920x1200 - external video adapter - 32 MB - black
Device Type External video adapter
Bus Type USB 2.0
Memory 32 MB SDRAM
Max Resolution 1920 x 1200
Interfaces DVI-I (Single-Link) , VGA - with adapter
Dimensions (WxDxH) 5.3 cm x 8.8 cm x 1.8 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB to DV...
£47.47
