StarTech.com USB to VGA Multi Monitor External Video Adapter
£38.18
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Compact, USB powered adapter provides the easiest way add a secondary or additional display to your PC
  • Completely external device offers a simple upgrade solution saving the cost and hassle of upgrading the internal video card on your system
  • The ability to use multiple adapters (up to five) provides a scalable display configuration for future expansion
  • Stock Status: In Stock
Product codes
The USB2VGAE2 USB to VGA external video adapter is the perfect multi-monitor VGA solution for office applications and Internet browsing.
The USB video adapter features a small form factor and enables a USB 2.0 port to be used with a VGA port. A cost-saving multi-monitor or dual display option that can be used as an external graphics card for either laptop or desktop applications.
The USB video adapter can be used with up to four additional (five total) USB2VGAE2 USB video adapters, creating multiple VGA connections that can be used to further extend or mirror the desktop shown on the existing display - all without having to open the computer case to add extra video cards.
Product Description StarTech.com USB to VGA Multi Monitor External Video Adapter - external video adapter - 16 MB - grey
Device Type External video adapter
Bus Type USB 2.0
Memory 16 MB SDRAM
Max Resolution 1680 x 1050
Interfaces VGA
Dimensions (WxDxH) 4.2 cm x 7.5 cm x 5 cm
Enclosure Colour Grey
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB to VG...
£38.18
