StarTech.com USB3.1 Dual External Enclosure
£92.32
Delivery:
Standard: 1-3 working days
Key features
  • Create powerful external storage with a 2-bay enclosure for 2.5” SSD/HDDs
  • Works with both USB-C and USB-A enabled devices, with two cables included
  • Compatible with Thunderbolt 3 USB-C port
  • Type: Storage enclosure
  • HD Size: 2.5"
  • Stock Status: In Stock
Product codes
Turn two 2.5" SATA SSDs or HDDs into high-performance storage with RAID - for USB-C and USB-A enabled devices. Compact in size but big on performance, this dual-bay enclosure provides powerful external data storage, with ultra-fast data transfer speeds and configurable RAID modes. It's ideal for small business and home office applications, or top-performing workstations for graphic designers, engineers and other business professionals.
Create a high-capacity, external data storage solution with support for two 2.5" SSDs/HDDs in a wide range of sizes from 5 to 12.5mm, with capacities up to and beyond 2TB. This aluminum enclosure delivers fast file transfer rates with USB 3.1 Gen 2 performance, supports SATA I, II and III and is enhanced with UASP to maximize the performance and speed of your SATA III drives. It even has a fan, with built-in speed control, to keep things running smoothly.
USB 3.1 Gen 2 gives you greater bandwidth and speed, supporting transfer rates of up to 10Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives while alleviating bottlenecks in your data transfers.
The dual-bay drive enclosure comes with two USB cables for flexible use with the latest laptops and tablets equipped with a USB-C port, as well as legacy devices. It includes both USB-C to Micro B and USB-A to Micro B cables. The 2-bay enclosure is also compatible with a Thunderbolt 3 USB-C port.
Through RAID 0 support, the dual-bay enclosure lets you maximize the performance of your SATA III SSDs to achieve greater file transfer speeds. The dual-bay enclosure also supports RAID 1, Big (Spanning or Concatenation) and JBOD. With multiple RAID options, you can gain increased storage size, performance, or redundancy.
The enclosure is OS independent, requiring no additional software or drivers.
Product Description StarTech.com USB 3.1 (10Gbps) External Enclosure for 2.5" SATA Hard Drives - RAID - 2-Bay USB Type-C Hard Drive Enclosure (S252BU313R) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Device Type Storage enclosure - external
Bus Type USB 3.1 (Gen 2)
Colour Black
Expansion Bays 2 x internal - 2.5"
Hard Drive Form Factor Compatibility 2.5"
Features Cooling fan
Interface SATA 6Gb/s
Data Transfer Rate 10 GBps
Supported Devices Hard drive, solid state drive
Max Storage Devices Qty 2
RAID Level RAID 0, RAID 1, JBOD, BIG
Product Material Aluminium
Power AC 120/230 V
Dimensions (WxDxH) 8.1 cm x 14.2 cm x 6 cm
Designed For P/N: PEXUSB311AC2, PEXUSB312C2, PEXUSB312EIC, TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB3.1 Du...
£92.32
