StarTech.com Vertical Dual Monitor Mount
£89.11
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Save space by mounting two monitors vertically with this dual monitor mount
  • Supports two displays 13” to 27”, or ultrawide displays up to 34" (max weight per monitor: 22.1 lb./10 kg)
  • The height of the monitors can be adjusted along the 27.5” (700 mm) pole
  • Stock Status: In Stock
Product codes
Save workspace and increase productivity by mounting two monitors, stacked, above your desk. This sturdy and sleek dual-monitor mount raises two displays off the surface of your desk or table, to save space while increasing your productivity. With its steel construction, the dual-monitor mount attaches easily to your desk or table to securely hold two monitors, each up to 27", stacked vertically.
The dual-monitor mount holds two displays, one above the other, in a vertical configuration. The height of the monitors can be adjusted, as required, along the 27.5" (700 mm) pole.
With the dual-monitor mount, you can work more comfortably, reducing neck and eye strain without having to look side to side when comparing files or reviewing reference material on your screens. It's ideal for numerous applications including web design, coding, creating and reviewing files, and many others. The monitor mount saves valuable desk space and lets you work clutter-free, which is a welcome addition in numerous office environments including business, healthcare, and financial settings.
The monitor mount enables smooth, effortless +45°/-45° tilt and +45°/-45° swivel, making it easy to reduce glare and find the perfect viewing angle. It can also rotate a full 360° giving you flexible viewing options.
The heavy-duty steel monitor mount holds your two monitors securely in place to protect your investment, and provide long-lasting performance. The dual-monitor mount supports two displays 13" to 27" (330 to 686 mm) in size and 22.1 lb. (10 kg) in weight per monitor. The surface finish features a powder coating to help resist scratches.
The dual-monitor mount makes it easy to mount your VESA mount compatible displays above your desk, table or other surfaces, using the included C-clamp or grommet mount. For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor into place and tighten the screw. To help keep your work area free of clutter, the monitor mount also features cable clips that keep your cables neatly out of sight.
Product Description StarTech.com Vertical Desk Mount Dual Monitor Arm - For Monitors 13" to 27" - Adjustable - Desk Clamp / Grommet-Hole Mount - Dual VESA Monitors - Black (ARMDUALV) - mounting kit - for 2 monitors - black
Product Type Mounting kit - desktop, desk-mountable
Dimensions (WxDxH) 11.6 cm x 12 cm x 90 cm
Tilt -45° to 45°
Pan -45° to 45°
Rotation 360°
Adjustments Tilt, swivel, rotation
Recommended Use 2 monitors
Recommended Display Size 13"-27"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 10 kg
Material Heavy duty steel
Colour Black
Package Content Mounting hardware
Manufacturer Warranty 5-year warranty
Designed For P/N: DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£89.11
