StarTech.com Vertical Dual Monitor Stand
£83.23
Delivery:
Standard: 1-3 working days
Key features
  • Mount two monitors vertically to save space and increase your comfort
  • Freestanding monitor stand supports two displays up to 27” (686 mm) in size and 22.1 lb. (10 kg) in weight per monitor
  • Heavy-duty steel construction
  • Stock Status: In Stock
Product codes
Increase productivity and free up space by mounting two monitors, stacked, with this attractive desktop stand. This sturdy and sleek dual-monitor stand raises two displays off the surface of your desk or table, to save space while increasing your productivity. With its steel construction, the freestanding monitor stand securely holds two monitors, each up to 27", stacked vertically.
The dual-monitor stand holds two displays, one above the other, in a vertical configuration. You can work more comfortably, reducing neck and eye strain without having to look side to side when comparing files or reviewing reference material on your screens. It's ideal for numerous applications including web design, coding, creating and reviewing files, and many others. The monitor mount saves valuable desk space and lets you work clutter-free, which is a welcome addition in numerous office environments including business, healthcare and financial settings. You can adjust the height of the monitors as needed, along the 32.2" (818 mm) pole.
The monitor stand enables smooth, effortless +45°/-45° tilt and +45°/-45° swivel, making it easy to reduce glare and find the perfect viewing angle. It can also rotate a full 360° giving you the flexibility of portrait or landscape viewing.
The heavy-duty steel monitor stand holds your monitors securely in place, to protect your investment and provide long-lasting stability. The dual-monitor stand supports two displays 13" to 27" (330 to 686 mm) in size and 22.1 lb. (10 kg) in weight per monitor. The surface finish features a powder coating to help resist scratches.
For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor into place and tighten the screw. To help keep your work area free of clutter, the monitor stand also features cable clips that keep your cables neatly out of sight.
Product Description StarTech.com Vertical Dual Monitor Stand - Steel - For Monitors up to 27in - stand
Product Type Stand - desktop stand
Dimensions (WxDxH) 43.4 cm x 31.6 cm x 81.8 cm
Tilt -45° to 45°
Pan -45° to 45°
Rotation 360°
Adjustments Height, tilt, swivel, rotation
Recommended Use 2 monitors
Recommended Display Size 13"-27"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 10 kg
Material Heavy duty steel
Colour Black
Package Content Mounting hardware
Manufacturer Warranty 5-year warranty
Designed For P/N: ACCSMNT
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Vertical...
£83.23
