StarTech.com VGA-Over-IP Video Extender
£233.58
Select:
  • VGA
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Collaborate with co-workers by using your network to easily switch between devices shown on a shared display
  • Share video with a wireless or wired LAN connection using any Windows computer on your network
  • Control the video-over-IP adapter, using the included software
Product codes
This VGA over IP extender lets you share a VGA display or projector with the wireless or wired computers on your network. The IP extender makes it easier than ever for users to collaborate and deliver presentations in boardrooms and office meetings, with intuitive controls and effortless screen sharing.
The IP video extender supports resolutions up to 1920x1200 and features two built-in USB ports and 3.5 mm audio set, enabling you to connect remote USB devices and speakers with a microphone to your computer from your display. It's the perfect solution for controlling a computer from wherever the adapter is located.
The IP video extender helps you boost your office productivity, by making it easier for users to collaborate and communicate. The included software lets you connect multiple computers and easily switch between which user is sharing their content with the VGA display, unlike some wireless video systems that are difficult to configure and require users to disconnect and reconnect manually.
You can even use the video-over-IP extender to share information with a remote audience, such as connecting to a remote display over an office LAN, to hold remote meetings while you're in another part of the office.
With this IP video extender, you can turn your VGA television, monitor or projector into an IP display that can connect to any Windows computer on your network. It's perfect for conference rooms and classrooms where different ideas are shared by users who bring their own computers.
With a built-in USB hub, you can use your computer to access two remote USB devices at your remote display, enabling you or your customers to control the computer from the remote location. Remote operation can be used to create interactive digital signage, to engage your customers. Or, if you're using the video-over-IP extender as part of your IT infrastructure, you can use the USB extender to add a remote KVM console that you can use to control your server from a remote location.
StarTech.com VGA Over IP Extender with 2-port USB Hub - 1920 x 1200 - video/audio extender - VGA
Video/audio extender
External
VGA
Max Transfer Distance
100 m
AC 120/230 V
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
14.3 cm x 16.8 cm x 6.3 cm
65 g
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com VGA-Over-...
£233.58
