StarTech.com VGA to Cat 5 Monitor Extender Kit (250ft/80m) -...
StarTech.com VGA to Cat 5 Monitor Extender Kit (250ft/80m) - VGA Cat5 Extender
£132.43
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Accessory Type: Projector Accessory
  • Stock Status: In Stock
Product codes
Extend a VGA signal to a remote display using Cat5 cabling.
The ST121UTPEP VGA Video Extender over Cat5 - Point to Point lets you connect a remote VGA display/projector up to 80m (250ft) away from the VGA signal source. The ST121UTPEP is a bundled kit that includes both a local and a remote unit providing a complete end to end solution for a single source/display connection, transmitting the source VGA signal over a standard Ethernet cable (Cat5e or better UTP cable, terminated with RJ45 connectors).
Offering convenient and cost-effective VGA distribution, the ST121UTPEP only requires one power adapter which can be installed at either the local or remote end of the connection, depending on what is most convenient for your application.
To ensure a tidy installation, the ST121UTPEP includes a mounting bracket for the receiver to help eliminate unnecessary cable tangles.
Product Description StarTech.com VGA to Cat 5 Monitor Extender Kit 250ft/80m VGA Extender - video extender
Device Type Video extender
Form Factor External
Max Transfer Distance 80 m
Dimensions (WxDxH) 10 cm x 13.8 cm x 2.5 cm
Weight 36 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com VGA to Ca...
£132.43
